Is a Amp needed?
If I use pc speakers where there is a volume knob on the speakers then self, do I still need a Amp or would a dac alone do the job?
(thinking about getting the nanosound and wondering if I need the Amp or not)
hi,
active speakers are ok, with audio jack (jack to jack) or an analogous card (cinch to jack). I used the second setup for testing with rpi.
edit: nanosound use an analougous card ==>> cinch to jack cable or you use the bad audio jack from the rpi. for bad active speakers is the rpi ok.
greets
hi i have a Dac nanosound basic, i would like some advice on some class d amplifier for 8 hom 83 db speakers. does anyone help me?
This should fit the bill nicely:
https://www.ebay.co.uk/itm/Mini-TPA3250-Stereo-Digital-Power-Amplifier-Hi-Fi-Home-Audio-Class-D-Amp-Silver/282759536542?epid=27010818503&hash=item41d5c81f9e:g:pPQAAOSwzbxadHoF
