Hey,
I’m using a chinese DAC Board (ES9038 Q2M) with my Raspberry Pi 4 and it has a IR header for installing a IR Receiver.
I only want to control playback since I control volume with my Integrated amp.
I found a cheap IR receiver on Audiophonics with a matching 38 kHz remote and want to know if this is compatible with the IR Remote Controller Plugin?
If it is compatible do I just have to solder the 3 pins accordingly and am good to go?
Products mentioned:
DAC BOARD:
RECEIVER:
