IR-Controler plugin has stopped working
The ir_controler plugin that worked very well suddenly stopped working while no modification was made on volumio
I don’t understand
I tried with several IR diodes, I uninstalled and reinstalled the plugin.
All this without result
Thank for your help
Have you tried using a different GPIO?
That’s odd. It’s still working for me. Could it be the remote?
SimonE, I have 2 remotes, the original 1294 Apple and a 1294 clone.
It doesn’t work with either of them.
Wheaten,
No, I haven’t taken that test. I’ll do it tomorrow.
I tried everything, but without success.
In the end, I did a complete reinstallation of Volumio, reinstalling the ir_remote plugin.
Volumio’s lirdc.conf file for the Apple remote is not good. I found the right one on this forum and now everything works.
Hi @Claude83 great to hear you sorted it out.
