As far as I understood ALL gpio pin can be populated on the top of the pi-dac+ (by adding/soldering a pin header)
Does this is correct ?
(in current setup (RPI B and USB-i2S DAC) I have LCD, temp & IR sensors connected to the GPIO and I want to be sure that I can connect them on the “populated” gpio)
is there any “populated” GPIO pin that CANNOT be used for “sth else” (i.e. pins which are reserved for the iqaudio dac+ to work)
Just got my RPI-DAC+
I’ve soldered the pin header (for the accessing the GPIO pins once the DAC is placed on the RPI-B+) and I checked on a multimeter each GPIO pin
Everything was fine except for the following pins :
GPIO-04 (pin 7) - GPIO GCLK
At reset only pins GPIO 14 & 15 are assigned to the alternate function UART (universal asynchronous receiver/transmitter)
I noticed, by looking on the top of the DAC that this pins are not linked to the “soldered” pin header, is there any particular reason for not connecting this pins ?
I recently got my hands on a PI3B mini board that has reduced GPIO pins and lacks GPIO 18/19/20/21 (I2S).
Is there any way to reassign the I2S pins on the PI so I can route utilize this small form factor PI board? I could then feasibly create a link from alterative GPIO pins to the correct ones on the DAC board?
