IQaudIO Pi-DAC+ HAT
Audiophile I2S DAC for the Raspberry Pi A+ and B+
No soldering required to your Raspberry Pi
Full HD Audio support (24/192)
TI PCM5122 Burr Brown derived Texas Instruments DAC
Built in HD audio quality Headphone Amplifier (TI TPA6133A) with 3.5mm Headphone socket
Built in hardware volume control for Line Out and Headphone
“Plug and play” HAT compliant Raspberry Pi accessory
The Pi-DAC+ just plugs right into the Raspberry Pi A+/B+, there’s no longer any need to solder anything to your Raspberry Pi and you can be enjoying Full HD audio in minutes.
The Pi-DAC+ feature the same great Texas Instruments PCM5122 DAC as the original and respected IQaudIO.com Pi-DAC, so you can be assured of great audio quality with built in hardware volume control.
The Pi-DAC+ also features a headphone amplifier delivering for the first time an all in one Full HD audio experience for those who listen through headphones, volume is again hardware based under software control and shared with Line Out.
A fully HAT compliant Raspberry Pi expansion board with EEPROM support, the Pi-DAC+ delivers Full HD audio from your Raspberry Pi. As the Pi-DAC+ uses the same audio chipset as the previous Pi-DAC full Linux device driver support is already built into the official Raspbian Linux distribution.
Can be purchased via Tindie.com (https://www.tindie.com/stores/IQaudIO/)
