iPhone > Pi2 + Volumio > ToppingVX1 USB amp ?
I would like to know if this setup is feasible?
iPhone --[wireless]–> Raspberry Pi 2 running Volumio --[USB]–> Topping VX1 amp (with integrated USB DAC)
The Topping VX1 has a USB type B input connector.
I have the Topping XVI, currently connected to my laptop, and I would like to add the Raspberry Pi 2 running Volumio to make a stand alone stereo without the need for the laptop.
According to the Topping VX1 specs, it has:
DAC: USB Controller by Burr-Brown PCM2704
Tripaths TA2024B chipset
I am a newbie, I apologize if I posted this in the wrong forum.
Edit: I found this post: https://volumio.org/forum/topping-vx1-with-integrated-dac-pops-clicks-t1304.html#p15070
which indicates that the Topping VX1 is compatible with Raspberry Pi + Volumio, at least one version.
I’m using the Topping VX1 with Volumio on a Raspberry Pi! Just plug the VX1 into the Pi using the same sort of USB cable as a printer (called an A to B cable). Works fine, but no hardware mixer controls unfortunately.
Thank you decryption! I’ve ordered the Pi 2 and am looking forward to trying it out. I love the Topping VX1, so the Pi2 + volumio + Topping VX1 should be a very inexpensive and great sounding music player.
And I’m glad you didn’t have to re-write the kernel or anything to get it to work!
I use to Topping DAC+Amp, and I’m wondering wich one to buy for my new low budget setup…
https://volumio.org/forum/topping-tp30-mark-versus-topping-vx1-t3426.html
Are you sure for volume control as my old TP30 and newer TP30 Mark 2, are both volume controllable via volumio GUI…
Is it a VX1 feature problem, or a driver problem with volumio ?
