Hiya, after a couple of weeks of great useage I can no longer connect to Volumio in any browser on any device.
I run Avahi Zeroconf and clicking on Volumio the IP address seems to change every other time.
Plus I can’t access volumio.local at all any more.
Would reinstalling the OS fix this or is the issue easier to diagnose?
Thanks again.
PS I’m definitely on the same network (otherwise Avahi wouldn’t see it) and the Pi3 is connected via LAN. Cheers.
