Introducing AudioTech: A dedicated UPnP/DLNA streaming controller & parametric EQ player for Volumio
Hi Volumio Community,
As an audio enthusiast and Volumio user, I built AudioTech — a lightweight, high-fidelity Android audio player and UPnP/DLNA streaming controller designed specifically for audiophiles and network streaming setups.
I wanted a modern Android app that could decode high-resolution local audio (FLAC, WAV, ALAC, MP3) with studio-grade DSP, while also acting as an all-in-one controller for Volumio and DIY streamers.
:star2: Key Highlights for Volumio Enthusiasts:
• Embedded Volumio Web UI (No PC Needed!):
Open and interact with your full Volumio Web UI directly inside the AudioTech app! You don’t need to open a separate browser or turn on your PC to manage Volumio settings, playlists, plugins, or sources — it’s all integrated right into your player dashboard.
• Lossless UPnP / DLNA Network Streaming:
Directly discovers and casts [PURE D2D] bit-perfect lossless audio over Wi-Fi to your Volumio streamers, Raspberry Pi DACs, smart speakers, and DLNA media renderers with low latency and gapless control.
• 64-bit Studio Parametric EQ (PEQ) & Graphic EQ:
Multi-band parametric equalizer featuring adjustable frequencies, Q-factors, and filter types (Peak, Low Shelf, High Shelf, High/Low Pass), alongside a precision 10-band graphic equalizer.
• Acoustic Soundstage & DSP Enhancements:
Includes Mid/Side stereo width widening, Haas effect spatial acoustic delay, headphone crossfeed, True-Peak limiter, and subsonic/ultrasonic audio filters.
• Real-Time 56-Band Spectrum Visualizer:
Multiple fluid animation styles including Dot Matrix, Solid Bars, Smooth Waveforms, Waterfall,
and Circular visualizers.
• Built-In “Room EQ Calculator” for Perfect, Tight Bass:
Tame muddy bass and boomy standing waves in your room! Simply input your room dimensions (length, width, height), and AudioTech automatically calculates the room’s axial resonance modes and applies targeted narrow notch filters to eliminate boominess and deliver clean, tight, punchy low-end response.
• Complete Library Management:
Fast browsing by multi-folder hierarchies (with multi-folder & SD card support), Albums, Playlists, and Favorites with instant disk caching.
• Global Internet Radio & Sleep Timer:
Stream high-bitrate radio stations or fall asleep to music with an automated sleep timer.
:calling: Download & Try on Google Play:
You can find AudioTech on the Google Play Store here:
:point_right: [AudioTech on Google Play Store]
I would love to hear feedback from fellow Volumio users on:
  1. The embedded Volumio Web UI experience on your phone.
  2. DLNA discovery and playback smoothness with your DAC/streamer setup.
  3. Any feature requests or custom DSP profiles you’d love to see next!
Thanks for checking it out, and happy listening! :musical_note:
