Internal storage space remaining
Hello, I loaded some music on my SD card for my USBridge with Volumio. How can I tell home much space I have left?
s is a community forum, for support specifically with myVolumio, email techsupport at volumio dot org!
You might have a look at the “Systeminfo” plugin. I think it also reports the amount of storage used and available. You can install the plugin from “Plugins” -> “Search Plugins” -> “Miscellanea”.
Fantastic, I’ll give it a try, fun stuff. Thanks a lot Richard
Oh there it is. Thanks for the help!
:+1:
Hi gvolt, so “memory” is RAM and “storage” is where my music files are correct? Looks like I have lots of room for more music if that is correct. Thanks for your help
re. RAM and storage, yes the latter is room for music files.
Fantastic, thanks you guys
