Internal Music not seen
In the latest version of Volumio, it appears as if it doesn’t actually see the music that is in the /data/INTERNAL/ folder.
The folders for each album are seen, but upon opening them there is nothing inside of the folders.
Yet under ssh I can plainly see that all the files are present.
With an external USB everything works great. Its just the INTERNAL folder that isn’t working.
Is their any fix for this.
Ronnie
In the settings under mymusic, I can rescan and update and it will see the folders under the INTERNAL, but it will not see the files.
Once I reboot it no longer sees the folders without rescanning again. But still will not see files.
Any way to make this work?
The external USB works great.
So I’m assuming no one else is experiencing this problem?
Or is just that there is no fix?
Perhaps look at file permissions? Or are they are a supported file type?
The files I’m looking at are mp3s.
I moved the exact same files to the usb drive and they work flawlessly.
