I have a few questions:
It seems that I can only play files from the hard drive I have attached after they have been added to the playlist. Is that correct?
I can’t find a way to select a folder full of files and play the whole bunch. The “Browse” window shows the files and folders, but when I click on a folder, it doesn’t select, but just opens the list inside. Can’t select and play more than a file at a time. How do I play an album?
Ideally I would like to select a bunch of things and shuffle. Actually, would love to shuffle a 1.5tb drive, but have seen elsewhere that it is impossible to shuffle a whole disk. Is that right? Seems like a major limitation–actually enough to drive to a different platform.
Looking at the “Playback” window, when I attempt to play a file the green circle on the left appears to fill in, but the numbers with it do not change from 00:00 and whatever the track length is, so I’m wondering if the file is actually playing. If the numbers don’t change when playing, then what are they there for, anyway.
I’m not getting any sound from the i2s DAC (eBay/Sellars 9018), so I’m wondering if the file is playing or not.
Really would like to get this thing into a useful state. Appreciate any thoughts on this.
–Buckapound
