l3VGV
February 17, 2018, 10:12am
1
Hello.
Im trying to get volumio 2.348 runung on my tablet, wich is based on intel z3735f SoC.
System boot thru UEFI, but failed to get GUI runing, i attached the dmesg output. Web UI an music playback is working.
Mint 18.3 is runing ok on that tablet, gui and all.
Is there any way i can do somsn myself to update graphic drivers or anything else?
dmesg.zip (18 KB)
chsims1
February 18, 2018, 7:47am
2
You might be interested to read this thread mini-intel-atom-z8300-problem-with-808622a8-sound-t8716.html . There is a link to a dev version with a newer kernel that may (or may not ) help.
l3VGV
February 18, 2018, 10:17am
3
At boot it say starting linux 3, not 4 as stated in gkkpch post, but in web UI it show version 17 febrary 2018. Is it whole new kernel there or only few modules?
Screen do not work anyway. dmesg show same errors in intel driver. no luck! seems i have to wait for a big update mr. gkkpch mentioned.
l3VGV
November 16, 2019, 2:26pm
4
I have attempted to boot latest version 2.668, but it wont work, same issue. Black screen.
l3VGV
November 16, 2019, 2:58pm
5
Okay i loged to console. dmesg
WARNING: CPU: 0 PID: 638 at drivers/gpu/drm/i915/intel_display.c:901 intel_wait_for_vblank+0x179/0x1d0 [i915]()
[ 27.732626] vblank wait on pipe A timed out
same as the last time.
Okay. but. If i startx manualy and then ctrl+c, it will restart X and screen come to live. But touch screen do not work anyway. Duh. pad on keyboard do work.
alot of errors in dmesg
[spoiler][ 1294.717928] ------------[ cut here ]------------
[ 1294.717968] WARNING: CPU: 0 PID: 882 at drivers/gpu/drm/i915/intel_display.c:3481 intel_crtc_wait_for_pending_flips+0x145/0x1b0 [i915]()
[ 1294.718035] Modules linked in: bnep bluetooth cpufreq_userspace cpufreq_stats cpufreq_powersave cpufreq_conservative xt_REDIRECT iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack ip_tables nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc cfg80211 rfkill snd_usb_audio snd_soc_sst_byt_rt5640_mach iTCO_wdt iTCO_vendor_support mcs7830 snd_usbmidi_lib snd_hwdep usbnet snd_seq_midi snd_seq_midi_event mii i915 snd_rawmidi evdev intel_powerclamp intel_rapl coretemp kvm_intel snd_soc_rt5640 kvm snd_soc_rl6231 snd_soc_core sg crc32_pclmul snd_compress crc32c_intel snd_pcm drm_kms_helper aesni_intel xts aes_i586 lrw gf128mul snd_seq drm pcspkr snd_seq_device ablk_helper efivars cryptd mmc_block snd_timer video snd lpc_ich thermal mfd_core button acpi_pad i2c_algo_bit
[ 1294.718071] ac soundcore iosf_mbi regmap_i2c battery i2c_designware_platform i2c_designware_core processor i2c_core thermal_sys snd_soc_sst_acpi fuse autofs4 vfat fat ext4 crc16 mbcache jbd2 ata_generic sata_via sata_sis pata_amd pata_via pata_sis pata_sch ata_piix sd_mod pata_atiixp usb_storage loop hid_generic hid_cherry usbhid hid sdhci_acpi sdhci_pci sdhci mmc_core xhci_pci xhci_hcd ohci_pci ohci_hcd uhci_hcd ehci_pci ehci_hcd usbcore usb_common nls_utf8 nls_cp437 squashfs overlay
[ 1294.718076] CPU: 0 PID: 882 Comm: Xorg Tainted: G W 3.18.25 #4
[ 1294.718078] Hardware name: Prestigio Multipad Visconte V/BYT-PF02, BIOS G1W_QI10X_PRESTIGIO_253 01/10/2017
[ 1294.718084] 00000000 f085bb3c c14f5bc0 00000000 c104f59e c15d7a60 00000000 00000372
[ 1294.718099] f90a2a24 00000d99 f904ede5 00000d99 f904ede5 00000009 00000000 f38a4600
[ 1294.718104] f62b0000 f085bb4c c104f660 00000009 00000000 f085bb84 f904ede5 00203286
[ 1294.718105] Call Trace:
[ 1294.718114] [<c14f5bc0>] ? dump_stack+0x3e/0x4e
[ 1294.718118] [<c104f59e>] ? warn_slowpath_common+0x8e/0xb0
[ 1294.718146] [<f904ede5>] ? intel_crtc_wait_for_pending_flips+0x145/0x1b0 [i915]
[ 1294.718172] [<f904ede5>] ? intel_crtc_wait_for_pending_flips+0x145/0x1b0 [i915]
[ 1294.718175] [<c104f660>] ? warn_slowpath_null+0x20/0x30
[ 1294.718201] [<f904ede5>] ? intel_crtc_wait_for_pending_flips+0x145/0x1b0 [i915]
[ 1294.718204] [<c10855f0>] ? wait_woken+0x50/0x50
[ 1294.718230] [<f905a535>] ? intel_crtc_set_config+0xa05/0xcb0 [i915]
[ 1294.718255] [<f8d35946>] ? drm_mode_set_config_internal+0x56/0xc0 [drm]
[ 1294.718262] [<f8e4806f>] ? restore_fbdev_mode+0xbf/0xe0 [drm_kms_helper]
[ 1294.718270] [<f8e49ae7>] ? drm_fb_helper_restore_fbdev_mode_unlocked+0x27/0x70 [drm_kms_helper]
[ 1294.718276] [<f8e49b52>] ? drm_fb_helper_set_par+0x22/0x50 [drm_kms_helper]
[ 1294.718301] [<f906474c>] ? intel_fbdev_set_par+0x1c/0x60 [i915]
[ 1294.718305] [<c12e464b>] ? fb_set_var+0x1ab/0x3e0
[ 1294.718322] [<f86d1648>] ? usb_hcd_link_urb_to_ep+0x18/0xb0 [usbcore]
[ 1294.718334] [<f8b7ba21>] ? prepare_transfer+0x101/0x110 [xhci_hcd]
[ 1294.718345] [<f8b7bd68>] ? xhci_urb_to_transfer_ring+0x38/0x50 [xhci_hcd]
[ 1294.718360] [<c12db494>] ? fbcon_blank+0x2d4/0x300
[ 1294.718366] [<c133a9e1>] ? do_unblank_screen+0xa1/0x1c0
[ 1294.718371] [<c1331698>] ? complete_change_console+0x58/0xe0
[ 1294.718374] [<c1332931>] ? vt_ioctl+0x1211/0x1290
[ 1294.718381] [<c1126ed6>] ? __generic_file_write_iter+0x256/0x4c0
[ 1294.718384] [<c1331720>] ? complete_change_console+0xe0/0xe0
[ 1294.718387] [<c1326a81>] ? tty_ioctl+0x251/0xaa0
[ 1294.718390] [<c1180510>] ? new_sync_read+0xa0/0xa0
[ 1294.718393] [<c1127186>] ? generic_file_write_iter+0x46/0xd0
[ 1294.718397] [<c11bd45f>] ? fsnotify+0x39f/0x560
[ 1294.718400] [<c1180510>] ? new_sync_read+0xa0/0xa0
[ 1294.718403] [<c118058b>] ? new_sync_write+0x7b/0xa0
[ 1294.718405] [<c1326830>] ? no_tty+0x40/0x40
[ 1294.718409] [<c1193523>] ? do_vfs_ioctl+0x343/0x540
[ 1294.718412] [<c1182bc3>] ? __sb_end_write+0x33/0x70
[ 1294.718415] [<c118106d>] ? vfs_write+0x15d/0x1d0
[ 1294.718418] [<c1193788>] ? SyS_ioctl+0x68/0xa0
[ 1294.718423] [<c14faf69>] ? syscall_call+0x7/0x7
[ 1294.718425] ---[ end trace 15cc23db1b5d6f21 ]---
[ 1294.718426] ------------[ cut here ]------------
[ 1294.718452] WARNING: CPU: 0 PID: 882 at drivers/gpu/drm/i915/intel_display.c:3487 intel_crtc_wait_for_pending_flips+0x19d/0x1b0 [i915]()
[ 1294.718453] Removing stuck page flip
[ 1294.718497] Modules linked in: bnep bluetooth cpufreq_userspace cpufreq_stats cpufreq_powersave cpufreq_conservative xt_REDIRECT iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack ip_tables nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc cfg80211 rfkill snd_usb_audio snd_soc_sst_byt_rt5640_mach iTCO_wdt iTCO_vendor_support mcs7830 snd_usbmidi_lib snd_hwdep usbnet snd_seq_midi snd_seq_midi_event mii i915 snd_rawmidi evdev intel_powerclamp intel_rapl coretemp kvm_intel snd_soc_rt5640 kvm snd_soc_rl6231 snd_soc_core sg crc32_pclmul snd_compress crc32c_intel snd_pcm drm_kms_helper aesni_intel xts aes_i586 lrw gf128mul snd_seq drm pcspkr snd_seq_device ablk_helper efivars cryptd mmc_block snd_timer video snd lpc_ich thermal mfd_core button acpi_pad i2c_algo_bit
[ 1294.718528] ac soundcore iosf_mbi regmap_i2c battery i2c_designware_platform i2c_designware_core processor i2c_core thermal_sys snd_soc_sst_acpi fuse autofs4 vfat fat ext4 crc16 mbcache jbd2 ata_generic sata_via sata_sis pata_amd pata_via pata_sis pata_sch ata_piix sd_mod pata_atiixp usb_storage loop hid_generic hid_cherry usbhid hid sdhci_acpi sdhci_pci sdhci mmc_core xhci_pci xhci_hcd ohci_pci ohci_hcd uhci_hcd ehci_pci ehci_hcd usbcore usb_common nls_utf8 nls_cp437 squashfs overlay
[ 1294.718531] CPU: 0 PID: 882 Comm: Xorg Tainted: G W 3.18.25 #4
[ 1294.718532] Hardware name: Prestigio Multipad Visconte V/BYT-PF02, BIOS G1W_QI10X_PRESTIGIO_253 01/10/2017
[ 1294.718538] 00000000 f085bb34 c14f5bc0 f085bb44 c104f59e f90acda1 f085bb60 00000372
[ 1294.718543] f90a2a24 00000d9f f904ee3d 00000d9f f904ee3d 00000009 f3ae94fc 00203297
[ 1294.718547] f62b0000 f085bb4c c104f5f3 00000009 f085bb44 f90acda1 f085bb60 f085bb84
[ 1294.718548] Call Trace:
[ 1294.718552] [<c14f5bc0>] ? dump_stack+0x3e/0x4e
[ 1294.718555] [<c104f59e>] ? warn_slowpath_common+0x8e/0xb0
[ 1294.718582] [<f904ee3d>] ? intel_crtc_wait_for_pending_flips+0x19d/0x1b0 [i915]
[ 1294.718608] [<f904ee3d>] ? intel_crtc_wait_for_pending_flips+0x19d/0x1b0 [i915]
[ 1294.718611] [<c104f5f3>] ? warn_slowpath_fmt+0x33/0x40
[ 1294.718637] [<f904ee3d>] ? intel_crtc_wait_for_pending_flips+0x19d/0x1b0 [i915]
[ 1294.718642] [<c10855f0>] ? wait_woken+0x50/0x50
[ 1294.718667] [<f905a535>] ? intel_crtc_set_config+0xa05/0xcb0 [i915]
[ 1294.718680] [<f8d35946>] ? drm_mode_set_config_internal+0x56/0xc0 [drm]
[ 1294.718687] [<f8e4806f>] ? restore_fbdev_mode+0xbf/0xe0 [drm_kms_helper]
[ 1294.718694] [<f8e49ae7>] ? drm_fb_helper_restore_fbdev_mode_unlocked+0x27/0x70 [drm_kms_helper]
[ 1294.718700] [<f8e49b52>] ? drm_fb_helper_set_par+0x22/0x50 [drm_kms_helper]
[ 1294.718724] [<f906474c>] ? intel_fbdev_set_par+0x1c/0x60 [i915]
[ 1294.718727] [<c12e464b>] ? fb_set_var+0x1ab/0x3e0
[ 1294.718742] [<f86d1648>] ? usb_hcd_link_urb_to_ep+0x18/0xb0 [usbcore]
[ 1294.718753] [<f8b7ba21>] ? prepare_transfer+0x101/0x110 [xhci_hcd]
[ 1294.718764] [<f8b7bd68>] ? xhci_urb_to_transfer_ring+0x38/0x50 [xhci_hcd]
[ 1294.718769] [<c12db494>] ? fbcon_blank+0x2d4/0x300
[ 1294.718774] [<c133a9e1>] ? do_unblank_screen+0xa1/0x1c0
[ 1294.718777] [<c1331698>] ? complete_change_console+0x58/0xe0
[ 1294.718781] [<c1332931>] ? vt_ioctl+0x1211/0x1290
[ 1294.718786] [<c1126ed6>] ? __generic_file_write_iter+0x256/0x4c0
[ 1294.718789] [<c1331720>] ? complete_change_console+0xe0/0xe0
[ 1294.718792] [<c1326a81>] ? tty_ioctl+0x251/0xaa0
[ 1294.718795] [<c1180510>] ? new_sync_read+0xa0/0xa0
[ 1294.718798] [<c1127186>] ? generic_file_write_iter+0x46/0xd0
[ 1294.718801] [<c11bd45f>] ? fsnotify+0x39f/0x560
[ 1294.718804] [<c1180510>] ? new_sync_read+0xa0/0xa0
[ 1294.718806] [<c118058b>] ? new_sync_write+0x7b/0xa0
[ 1294.718809] [<c1326830>] ? no_tty+0x40/0x40
[ 1294.718812] [<c1193523>] ? do_vfs_ioctl+0x343/0x540
[ 1294.718815] [<c1182bc3>] ? __sb_end_write+0x33/0x70
[ 1294.718818] [<c118106d>] ? vfs_write+0x15d/0x1d0
[ 1294.718821] [<c1193788>] ? SyS_ioctl+0x68/0xa0
[ 1294.718825] [<c14faf69>] ? syscall_call+0x7/0x7
[ 1294.718826] ---[ end trace 15cc23db1b5d6f22 ]---
[ 1294.782003] ------------[ cut here ]------------
[ 1294.782101] WARNING: CPU: 0 PID: 882 at drivers/gpu/drm/i915/intel_display.c:901 intel_wait_for_vblank+0x179/0x1d0 [i915]()
[ 1294.782112] vblank wait on pipe A timed out
[ 1294.782160] Modules linked in: bnep bluetooth cpufreq_userspace cpufreq_stats cpufreq_powersave cpufreq_conservative xt_REDIRECT iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack ip_tables nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc cfg80211 rfkill snd_usb_audio snd_soc_sst_byt_rt5640_mach iTCO_wdt iTCO_vendor_support mcs7830 snd_usbmidi_lib snd_hwdep usbnet snd_seq_midi snd_seq_midi_event mii i915 snd_rawmidi evdev intel_powerclamp intel_rapl coretemp kvm_intel snd_soc_rt5640 kvm snd_soc_rl6231 snd_soc_core sg crc32_pclmul snd_compress crc32c_intel snd_pcm drm_kms_helper aesni_intel xts aes_i586 lrw gf128mul snd_seq drm pcspkr snd_seq_device ablk_helper efivars cryptd mmc_block snd_timer video snd lpc_ich thermal mfd_core button acpi_pad i2c_algo_bit
[ 1294.782202] ac soundcore iosf_mbi regmap_i2c battery i2c_designware_platform i2c_designware_core processor i2c_core thermal_sys snd_soc_sst_acpi fuse autofs4 vfat fat ext4 crc16 mbcache jbd2 ata_generic sata_via sata_sis pata_amd pata_via pata_sis pata_sch ata_piix sd_mod pata_atiixp usb_storage loop hid_generic hid_cherry usbhid hid sdhci_acpi sdhci_pci sdhci mmc_core xhci_pci xhci_hcd ohci_pci ohci_hcd uhci_hcd ehci_pci ehci_hcd usbcore usb_common nls_utf8 nls_cp437 squashfs overlay
[ 1294.782206] CPU: 0 PID: 882 Comm: Xorg Tainted: G W 3.18.25 #4
[ 1294.782208] Hardware name: Prestigio Multipad Visconte V/BYT-PF02, BIOS G1W_QI10X_PRESTIGIO_253 01/10/2017
[ 1294.782214] 00000000 f085bb00 c14f5bc0 f085bb10 c104f59e f90a447c f085bb2c 00000372
[ 1294.782219] f90a2a24 00000385 f904c809 00000385 f904c809 00000009 f38a0000 001f0040
[ 1294.782224] 00000a89 f085bb18 c104f5f3 00000009 f085bb10 f90a447c f085bb2c f085bb44
[ 1294.782225] Call Trace:
[ 1294.782232] [<c14f5bc0>] ? dump_stack+0x3e/0x4e
[ 1294.782236] [<c104f59e>] ? warn_slowpath_common+0x8e/0xb0
[ 1294.782264] [<f904c809>] ? intel_wait_for_vblank+0x179/0x1d0 [i915]
[ 1294.782290] [<f904c809>] ? intel_wait_for_vblank+0x179/0x1d0 [i915]
[ 1294.782293] [<c104f5f3>] ? warn_slowpath_fmt+0x33/0x40
[ 1294.782319] [<f904c809>] ? intel_wait_for_vblank+0x179/0x1d0 [i915]
[ 1294.782356] [<f90573d1>] ? intel_pipe_set_base+0x161/0x370 [i915]
[ 1294.782381] [<f904ed9b>] ? intel_crtc_wait_for_pending_flips+0xfb/0x1b0 [i915]
[ 1294.782408] [<f905a548>] ? intel_crtc_set_config+0xa18/0xcb0 [i915]
[ 1294.782423] [<f8d35946>] ? drm_mode_set_config_internal+0x56/0xc0 [drm]
[ 1294.782439] [<f8e4806f>] ? restore_fbdev_mode+0xbf/0xe0 [drm_kms_helper]
[ 1294.782446] [<f8e49ae7>] ? drm_fb_helper_restore_fbdev_mode_unlocked+0x27/0x70 [drm_kms_helper]
[ 1294.782452] [<f8e49b52>] ? drm_fb_helper_set_par+0x22/0x50 [drm_kms_helper]
[ 1294.782477] [<f906474c>] ? intel_fbdev_set_par+0x1c/0x60 [i915]
[ 1294.782481] [<c12e464b>] ? fb_set_var+0x1ab/0x3e0
[ 1294.782498] [<f86d1648>] ? usb_hcd_link_urb_to_ep+0x18/0xb0 [usbcore]
[ 1294.782509] [<f8b7ba21>] ? prepare_transfer+0x101/0x110 [xhci_hcd]
[ 1294.782521] [<f8b7bd68>] ? xhci_urb_to_transfer_ring+0x38/0x50 [xhci_hcd]
[ 1294.782526] [<c12db494>] ? fbcon_blank+0x2d4/0x300
[ 1294.782531] [<c133a9e1>] ? do_unblank_screen+0xa1/0x1c0
[ 1294.782536] [<c1331698>] ? complete_change_console+0x58/0xe0
[ 1294.782539] [<c1332931>] ? vt_ioctl+0x1211/0x1290
[ 1294.782545] [<c1126ed6>] ? __generic_file_write_iter+0x256/0x4c0
[ 1294.782549] [<c1331720>] ? complete_change_console+0xe0/0xe0
[ 1294.782571] [<c1326a81>] ? tty_ioctl+0x251/0xaa0
[ 1294.782575] [<c1180510>] ? new_sync_read+0xa0/0xa0
[ 1294.782577] [<c1127186>] ? generic_file_write_iter+0x46/0xd0
[ 1294.782582] [<c11bd45f>] ? fsnotify+0x39f/0x560
[ 1294.782584] [<c1180510>] ? new_sync_read+0xa0/0xa0
[ 1294.782587] [<c118058b>] ? new_sync_write+0x7b/0xa0
[ 1294.782589] [<c1326830>] ? no_tty+0x40/0x40
[ 1294.782593] [<c1193523>] ? do_vfs_ioctl+0x343/0x540
[ 1294.782596] [<c1182bc3>] ? __sb_end_write+0x33/0x70
[ 1294.782599] [<c118106d>] ? vfs_write+0x15d/0x1d0
[ 1294.782602] [<c1193788>] ? SyS_ioctl+0x68/0xa0
[ 1294.782606] [<c14faf69>] ? syscall_call+0x7/0x7
[ 1294.782608] ---[ end trace 15cc23db1b5d6f23 ]---
[ 1296.218843] ------------[ cut here ]------------
[ 1296.218972] WARNING: CPU: 2 PID: 4541 at drivers/gpu/drm/i915/intel_display.c:901 intel_wait_for_vblank+0x179/0x1d0 [i915]()
[ 1296.218984] vblank wait on pipe A timed out
[ 1296.218992] Modules linked in: bnep bluetooth cpufreq_userspace cpufreq_stats cpufreq_powersave cpufreq_conservative xt_REDIRECT iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack ip_tables nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc cfg80211 rfkill snd_usb_audio snd_soc_sst_byt_rt5640_mach iTCO_wdt iTCO_vendor_support mcs7830 snd_usbmidi_lib snd_hwdep usbnet snd_seq_midi snd_seq_midi_event mii i915 snd_rawmidi evdev intel_powerclamp intel_rapl coretemp kvm_intel snd_soc_rt5640 kvm snd_soc_rl6231 snd_soc_core sg crc32_pclmul snd_compress crc32c_intel snd_pcm drm_kms_helper aesni_intel xts aes_i586 lrw gf128mul snd_seq drm pcspkr snd_seq_device ablk_helper efivars cryptd mmc_block snd_timer video snd lpc_ich thermal mfd_core button acpi_pad i2c_algo_bit
[ 1296.219243] ac soundcore iosf_mbi regmap_i2c battery i2c_designware_platform i2c_designware_core processor i2c_core thermal_sys snd_soc_sst_acpi fuse autofs4 vfat fat ext4 crc16 mbcache jbd2 ata_generic sata_via sata_sis pata_amd pata_via pata_sis pata_sch ata_piix sd_mod pata_atiixp usb_storage loop hid_generic hid_cherry usbhid hid sdhci_acpi sdhci_pci sdhci mmc_core xhci_pci xhci_hcd ohci_pci ohci_hcd uhci_hcd ehci_pci ehci_hcd usbcore usb_common nls_utf8 nls_cp437 squashfs overlay
[ 1296.219427] CPU: 2 PID: 4541 Comm: Xorg Tainted: G W 3.18.25 #4
[ 1296.219438] Hardware name: Prestigio Multipad Visconte V/BYT-PF02, BIOS G1W_QI10X_PRESTIGIO_253 01/10/2017
[ 1296.219448] 00000002 df18bcfc c14f5bc0 df18bd0c c104f59e f90a447c df18bd28 000011bd
[ 1296.219480] f90a2a24 00000385 f904c809 00000385 f904c809 00000009 f38a0000 001f0040
[ 1296.219511] 00000a89 df18bd14 c104f5f3 00000009 df18bd0c f90a447c df18bd28 df18bd40
[ 1296.219542] Call Trace:
[ 1296.219569] [<c14f5bc0>] ? dump_stack+0x3e/0x4e
[ 1296.219591] [<c104f59e>] ? warn_slowpath_common+0x8e/0xb0
[ 1296.219699] [<f904c809>] ? intel_wait_for_vblank+0x179/0x1d0 [i915]
[ 1296.219800] [<f904c809>] ? intel_wait_for_vblank+0x179/0x1d0 [i915]
[ 1296.219820] [<c104f5f3>] ? warn_slowpath_fmt+0x33/0x40
[ 1296.219924] [<f904c809>] ? intel_wait_for_vblank+0x179/0x1d0 [i915]
[ 1296.220029] [<f90573d1>] ? intel_pipe_set_base+0x161/0x370 [i915]
[ 1296.220129] [<f904ed9b>] ? intel_crtc_wait_for_pending_flips+0xfb/0x1b0 [i915]
[ 1296.220232] [<f905a548>] ? intel_crtc_set_config+0xa18/0xcb0 [i915]
[ 1296.220285] [<f8d39fc5>] ? drm_mode_setcrtc+0x375/0x590 [drm]
[ 1296.220340] [<f8d35946>] ? drm_mode_set_config_internal+0x56/0xc0 [drm]
[ 1296.220390] [<f8d39e8c>] ? drm_mode_setcrtc+0x23c/0x590 [drm]
[ 1296.220442] [<f8d39c50>] ? drm_mode_setplane+0x250/0x250 [drm]
[ 1296.220486] [<f8d2c305>] ? drm_ioctl+0x1f5/0x660 [drm]
[ 1296.220507] [<c128a578>] ? lockref_get_not_dead+0x8/0x30
[ 1296.220557] [<f8d39c50>] ? drm_mode_setplane+0x250/0x250 [drm]
[ 1296.220610] [<f8d2c110>] ? drm_getmap+0xc0/0xc0 [drm]
[ 1296.220631] [<c1193523>] ? do_vfs_ioctl+0x343/0x540
[ 1296.220649] [<c128a548>] ? lockref_put_or_lock+0x8/0x30
[ 1296.220668] [<c1196e94>] ? dput+0x24/0x1a0
[ 1296.220689] [<c10a2f6c>] ? call_rcu_sched+0x1c/0x20
[ 1296.220710] [<c117f2e0>] ? SyS_access+0x190/0x1f0
[ 1296.220729] [<c1193788>] ? SyS_ioctl+0x68/0xa0
[ 1296.220750] [<c14faf69>] ? syscall_call+0x7/0x7
[ 1296.220763] ---[ end trace 15cc23db1b5d6f24 ]---
[ 1296.986473] [drm:dpi_send_cmd] *ERROR* Video mode command 0x00000041 send failed.
[ 1297.066460] ------------[ cut here ]------------
[ 1297.066588] WARNING: CPU: 0 PID: 4541 at drivers/gpu/drm/i915/intel_display.c:901 intel_wait_for_vblank+0x179/0x1d0 [i915]()
[ 1297.066643] vblank wait on pipe A timed out
[ 1297.066674] Modules linked in: bnep bluetooth cpufreq_userspace cpufreq_stats cpufreq_powersave cpufreq_conservative xt_REDIRECT iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack ip_tables nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc cfg80211 rfkill snd_usb_audio snd_soc_sst_byt_rt5640_mach iTCO_wdt iTCO_vendor_support mcs7830 snd_usbmidi_lib snd_hwdep usbnet snd_seq_midi snd_seq_midi_event mii i915 snd_rawmidi evdev intel_powerclamp intel_rapl coretemp kvm_intel snd_soc_rt5640 kvm snd_soc_rl6231 snd_soc_core sg crc32_pclmul snd_compress crc32c_intel snd_pcm drm_kms_helper aesni_intel xts aes_i586 lrw gf128mul snd_seq drm pcspkr snd_seq_device ablk_helper efivars cryptd mmc_block snd_timer video snd lpc_ich thermal mfd_core button acpi_pad i2c_algo_bit
[ 1297.066992] ac soundcore iosf_mbi regmap_i2c battery i2c_designware_platform i2c_designware_core processor i2c_core thermal_sys snd_soc_sst_acpi fuse autofs4 vfat fat ext4 crc16 mbcache jbd2 ata_generic sata_via sata_sis pata_amd pata_via pata_sis pata_sch ata_piix sd_mod pata_atiixp usb_storage loop hid_generic hid_cherry usbhid hid sdhci_acpi sdhci_pci sdhci mmc_core xhci_pci xhci_hcd ohci_pci ohci_hcd uhci_hcd ehci_pci ehci_hcd usbcore usb_common nls_utf8 nls_cp437 squashfs overlay
[ 1297.067086] CPU: 0 PID: 4541 Comm: Xorg Tainted: G W 3.18.25 #4
[ 1297.067089] Hardware name: Prestigio Multipad Visconte V/BYT-PF02, BIOS G1W_QI10X_PRESTIGIO_253 01/10/2017
[ 1297.067093] 00000000 df18bc68 c14f5bc0 df18bc78 c104f59e f90a447c df18bc94 000011bd
[ 1297.067102] f90a2a24 00000385 f904c809 00000385 f904c809 00000009 f38a0000 001f0040
[ 1297.067110] 00000a89 df18bc80 c104f5f3 00000009 df18bc78 f90a447c df18bc94 df18bcac
[ 1297.067119] Call Trace:
[ 1297.067129] [<c14f5bc0>] ? dump_stack+0x3e/0x4e
[ 1297.067136] [<c104f59e>] ? warn_slowpath_common+0x8e/0xb0
[ 1297.067166] [<f904c809>] ? intel_wait_for_vblank+0x179/0x1d0 [i915]
[ 1297.067205] [<f904c809>] ? intel_wait_for_vblank+0x179/0x1d0 [i915]
[ 1297.067210] [<c104f5f3>] ? warn_slowpath_fmt+0x33/0x40
[ 1297.067239] [<f904c809>] ? intel_wait_for_vblank+0x179/0x1d0 [i915]
[ 1297.067267] [<f905628e>] ? i9xx_crtc_disable+0x8e/0x6a0 [i915]
[ 1297.067304] [<f9046254>] ? valleyview_get_vco+0x54/0x70 [i915]
[ 1297.067333] [<f9050b27>] ? __intel_set_mode+0x267/0x15d0 [i915]
[ 1297.067361] [<f9059c1a>] ? intel_crtc_set_config+0xea/0xcb0 [i915]
[ 1297.067389] [<f90595b7>] ? intel_set_mode+0x27/0x40 [i915]
[ 1297.067416] [<f905a48d>] ? intel_crtc_set_config+0x95d/0xcb0 [i915]
[ 1297.067430] [<c14f8add>] ? __ww_mutex_lock+0x1d/0xb0
[ 1297.067448] [<f8d35946>] ? drm_mode_set_config_internal+0x56/0xc0 [drm]
[ 1297.067462] [<f8d35ae2>] ? drm_framebuffer_remove+0xc2/0x120 [drm]
[ 1297.067477] [<f8d3a509>] ? drm_mode_rmfb+0xb9/0xf0 [drm]
[ 1297.067490] [<f8d3a450>] ? drm_mode_addfb2+0xb0/0xb0 [drm]
[ 1297.067502] [<f8d2c305>] ? drm_ioctl+0x1f5/0x660 [drm]
[ 1297.067516] [<f8d3a450>] ? drm_mode_addfb2+0xb0/0xb0 [drm]
[ 1297.067544] [<c13f933d>] ? skb_dequeue+0x4d/0x70
[ 1297.067550] [<c13fa81c>] ? skb_queue_purge+0x1c/0x30
[ 1297.067556] [<c11a830a>] ? __inode_wait_for_writeback+0x5a/0xa0
[ 1297.067569] [<f8d2c110>] ? drm_getmap+0xc0/0xc0 [drm]
[ 1297.067576] [<c1193523>] ? do_vfs_ioctl+0x343/0x540
[ 1297.067581] [<c119af3f>] ? destroy_inode+0x2f/0x60
[ 1297.067586] [<c1059653>] ? recalc_sigpending+0x13/0x50
[ 1297.067591] [<c105cc03>] ? __set_current_blocked+0x33/0x50
[ 1297.067596] [<c105cd53>] ? sigprocmask+0x73/0xc0
[ 1297.067602] [<c1193788>] ? SyS_ioctl+0x68/0xa0
[ 1297.067608] [<c14faf69>] ? syscall_call+0x7/0x7
[ 1297.067612] ---[ end trace 15cc23db1b5d6f25 ]---
[ 1297.202636] ------------[ cut here ]------------
[ 1297.202705] WARNING: CPU: 1 PID: 4541 at drivers/gpu/drm/i915/intel_display.c:994 intel_disable_pipe+0x23d/0x250 [i915]()
[ 1297.202708] pipe_off wait timed out
[ 1297.202711] Modules linked in: bnep bluetooth cpufreq_userspace cpufreq_stats cpufreq_powersave cpufreq_conservative xt_REDIRECT iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack ip_tables nfsd auth_rpcgss oid_registry nfs_acl nfs lockd grace fscache sunrpc cfg80211 rfkill snd_usb_audio snd_soc_sst_byt_rt5640_mach iTCO_wdt iTCO_vendor_support mcs7830 snd_usbmidi_lib snd_hwdep usbnet snd_seq_midi snd_seq_midi_event mii i915 snd_rawmidi evdev intel_powerclamp intel_rapl coretemp kvm_intel snd_soc_rt5640 kvm snd_soc_rl6231 snd_soc_core sg crc32_pclmul snd_compress crc32c_intel snd_pcm drm_kms_helper aesni_intel xts aes_i586 lrw gf128mul snd_seq drm pcspkr snd_seq_device ablk_helper efivars cryptd mmc_block snd_timer video snd lpc_ich thermal mfd_core button acpi_pad i2c_algo_bit
[ 1297.202795] ac soundcore iosf_mbi regmap_i2c battery i2c_designware_platform i2c_designware_core processor i2c_core thermal_sys snd_soc_sst_acpi fuse autofs4 vfat fat ext4 crc16 mbcache jbd2 ata_generic sata_via sata_sis pata_amd pata_via pata_sis pata_sch ata_piix sd_mod pata_atiixp usb_storage loop hid_generic hid_cherry usbhid hid sdhci_acpi sdhci_pci sdhci mmc_core xhci_pci xhci_hcd ohci_pci ohci_hcd uhci_hcd ehci_pci ehci_hcd usbcore usb_common nls_utf8 nls_cp437 squashfs overlay
[ 1297.202857] CPU: 1 PID: 4541 Comm: Xorg Tainted: G W 3.18.25 #4
[ 1297.202861] Hardware name: Prestigio Multipad Visconte V/BYT-PF02, BIOS G1W_QI10X_PRESTIGIO_253 01/10/2017
[ 1297.202865] 00000001 df18bc6c c14f5bc0 df18bc7c c104f59e f90acd0c df18bc98 000011bd
[ 1297.202875] f90a2a24 000003e2 f904bdfd 000003e2 f904bdfd 00000009 000003e2 001f0008
[ 1297.202884] 0003ce0b df18bc84 c104f5f3 00000009 df18bc7c f90acd0c df18bc98 df18bcac
[ 1297.202894] Call Trace:
[ 1297.202904] [<c14f5bc0>] ? dump_stack+0x3e/0x4e
[ 1297.202912] [<c104f59e>] ? warn_slowpath_common+0x8e/0xb0
[ 1297.202946] [<f904bdfd>] ? intel_disable_pipe+0x23d/0x250 [i915]
[ 1297.202978] [<f904bdfd>] ? intel_disable_pipe+0x23d/0x250 [i915]
[ 1297.202984] [<c104f5f3>] ? warn_slowpath_fmt+0x33/0x40
[ 1297.203017] [<f904bdfd>] ? intel_disable_pipe+0x23d/0x250 [i915]
[ 1297.203050] [<f9056295>] ? i9xx_crtc_disable+0x95/0x6a0 [i915]
[ 1297.203081] [<f9046254>] ? valleyview_get_vco+0x54/0x70 [i915]
[ 1297.203113] [<f9050b27>] ? __intel_set_mode+0x267/0x15d0 [i915]
[ 1297.203146] [<f9059c1a>] ? intel_crtc_set_config+0xea/0xcb0 [i915]
[ 1297.203178] [<f90595b7>] ? intel_set_mode+0x27/0x40 [i915]
[ 1297.203209] [<f905a48d>] ? intel_crtc_set_config+0x95d/0xcb0 [i915]
[ 1297.203216] [<c14f8add>] ? __ww_mutex_lock+0x1d/0xb0
[ 1297.203235] [<f8d35946>] ? drm_mode_set_config_internal+0x56/0xc0 [drm]
[ 1297.203251] [<f8d35ae2>] ? drm_framebuffer_remove+0xc2/0x120 [drm]
[ 1297.203268] [<f8d3a509>] ? drm_mode_rmfb+0xb9/0xf0 [drm]
[ 1297.203283] [<f8d3a450>] ? drm_mode_addfb2+0xb0/0xb0 [drm]
[ 1297.203297] [<f8d2c305>] ? drm_ioctl+0x1f5/0x660 [drm]
[ 1297.203313] [<f8d3a450>] ? drm_mode_addfb2+0xb0/0xb0 [drm]
[ 1297.203322] [<c13f933d>] ? skb_dequeue+0x4d/0x70
[ 1297.203328] [<c13fa81c>] ? skb_queue_purge+0x1c/0x30
[ 1297.203335] [<c11a830a>] ? __inode_wait_for_writeback+0x5a/0xa0
[ 1297.203350] [<f8d2c110>] ? drm_getmap+0xc0/0xc0 [drm]
[ 1297.203357] [<c1193523>] ? do_vfs_ioctl+0x343/0x540
[ 1297.203363] [<c119af3f>] ? destroy_inode+0x2f/0x60
[ 1297.203369] [<c1059653>] ? recalc_sigpending+0x13/0x50
[ 1297.203375] [<c105cc03>] ? __set_current_blocked+0x33/0x50
[ 1297.203381] [<c105cd53>] ? sigprocmask+0x73/0xc0
[ 1297.203387] [<c1193788>] ? SyS_ioctl+0x68/0xa0
[ 1297.203394] [<c14faf69>] ? syscall_call+0x7/0x7
[ 1297.203398] ---[ end trace 15cc23db1b5d6f26 ]---
[/spoiler]
gkkpch
November 16, 2019, 3:32pm
6
Yep, this still has the very ancient kernel, which will not support newer panels and only a few touch interfaces.
I’m working with a new kernel version, with a Volumio OS versionbased on Debian buster, which has been tested by a number of people.
Hopefully we can show an alpha version soon, using the upcoming kernel 5.4 LTS
l3VGV
November 17, 2019, 2:46pm
7
I found that test version
it works! it works!!! GUI start up fine, touch working great. only gyro mising, so it not react on rotation of device, but anyway, that a minor issue for me now, im so happy
It take some time to start, and sometime browser show “no connection”, but anyway!
and network scan do not work, and do not see local SD card library. And web radio do not work. But GUI does. lol
well im back on 2.668 and web UI.
And, after i booted 2.668 after 2.416, screen come to life(touch do not). Go figure.
