Thanks for a awesome build, was a user of Daphile earlier, but Volumio sounds much better.
I was able to install Volumio in Intel NUC successfully and was able to play media, but wifi does not seem to be supporting. I get no list of wifi networks in system menu, and even if i switch ON hotspot it will be automatically turned OFF once i leave the screen inspite of saving the settings.
Wifi device used is Intel 3650 (standard fitment in 5PPYH)
Roberto is right, we know newer devices have issues. Not a matter of kernel version only (new kernel works fine), we also need new firmware packages. Unfortunately these packages are not available for Debian jessie Volumio currently is based on. We plan to port to Debian stretch and then the Intel wifi will be supported.
This takes time plus I don’t have the hardware to test with.
