I am having real problems getting my NAS drive to mount. I have tried everything suggested on this forum only managed once as soon as I rebooted NAS lost. I’ve updated image installed cifs-utils problem not solved. When I sudo mount from command line Nas drive does not show up. Their is no problem with NAS drives as I can access them on some rasberry pi. Is their a way to mount via command line e.g. editing etc/fstab is so please help.
For Volumio to connect to a CIFS share on my Win7 network I deleted the parameter ‘noatime’ from ‘Mount flags’ under ‘…advanced options’ when setting up the network mount. It may work for your NAS too.
Andrew
Maybe this can help you.
