Volumio Information 2.915
Volumio Version: v
Hardware: x86 laptop
DAC:Cyrus QX
Hi, I’m considering purchasing a mini PC rather than using my ageing laptop. Is there any problems with using this type of device rather than a Raspberry Pi.
Volumio Version: v
DAC:Cyrus QX
Difficult to answer, the PI’s come in fixed configurations, with x86 you have zillion different ones. Although most of them will work, there is no guarantee.
The best thing you can do is ask this community if a specific mini PC has been tested before buying it.
This could help, note it is not up-to-date.
Compatible x86 devices
You can try to setup a vbox to see if it works with your DAC.
In my case no issue so far except for Guest additions which can’t be installed on kernel 5 apparently.
