Installation Guide on Debian Jessie
Hi I´ve an Pi3 an whont to know is its possible to install volumio on a debian jessie existing OS.
Is there any step by step guide?
Thanks for helping me.
Best expression
currently no, you cannot install Volumio 2 on an existing Debian Jessie OS.
Volumio depends on it’s own minimal set of packages and customized initrd and squased root filesystem.
You can have a look at GitHub - volumio/Build: Buildscripts for Volumio System to get an idea how the images are being built.
Hallo,
i read the installations guide
Build
required : squashfs-tools kpartx multistrap qemu-user-static samba debootstrap parted dosfstools qemu binfmt-support
required for building x86 : qemu-utils
clone the build repo on your local folder : git clone [github.com/volumio/Build](https://github.com/volumio/Build) build
cd to /build and type ./build.sh -b -d all -v 2.0 where switches are :
    -b --Build system with Multistrap, use arm or x86 to select architecture
    -d --Create Image for Specific Devices. Usage: all (all), pi, udoo, cuboxi, bbb, cubietruck, compulab
    -l --Create docker layer. Docker Repository name as as argument
    -v --Version
Example: Build a Raspberry PI image from scratch, version 2.0 : ./build.sh -b arm -d pi -v 2.0 -l reponame
when i type ./build.sh -b x86 -v 2.0
the build start. —> ok
my question is:
where is the img file?
my system: debian 8 clean install
the output is
Creating Volumio Folder Structure
mkdir: cannot create directory ‘/media’: File exists
Prepping MPD environment
Adding Volumio Parent Service to Startup
Adding Volumio Remote Updater Service to Startup
Adding Udisks-glue service to Startup
Setting Mpd to SystemD instead of Init
Synchronizing state for mpd.service with sysvinit using update-rc.d…
Executing /usr/sbin/update-rc.d mpd defaults
Executing /usr/sbin/update-rc.d mpd enable
Adding Users to Audio Group
Setting RT Priority to Audio Group
Alsa tuning
Creating Alsa state file
Tuning LAN
Disabling IPV6
#disable ipv6
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
net.ipv6.conf.lo.disable_ipv6 = 1
Adding information in os-release
Base System Installed
Writing system information
Unmounting Temp devices
Copying Custom Volumio System Files
Copying X86 related Configuration files
Done Copying Custom Volumio System Files
root@debian:/home/volumio/build#
