Install peppy meter in volumio
alsa pipeline is to be activated only once.
I know, but when I check after a reboot, both lines are false again
I have configured .env now
Do a reboot
**volumio@vtest**:**/volumio**$ su
Password:
bash-5.0# echo ā€˜/opt/vc/lib’ >/etc/ld.so.conf.d/00-vmcs.conf
bash-5.0# /sbin/ldconfig
bash-5.0#
bash-5.0# wget https://github.com/balbuze/volumio-plugins/raw/alsa_modular/plugins/miscellanea/peppyMeter/pipe.zip
--2021-02-23 19:49:17--  https://github.com/balbuze/volumio-plugins/raw/alsa_modular/plugins/miscellanea/peppyMeter/pipe.zip
Resolving github.com (github.com)... 140.82.121.3
Connecting to github.com (github.com)|140.82.121.3|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://raw.githubusercontent.com/balbuze/volumio-plugins/alsa_modular/plugins/miscellanea/peppyMeter/pipe.zip [following]
--2021-02-23 19:49:18--  https://raw.githubusercontent.com/balbuze/volumio-plugins/alsa_modular/plugins/miscellanea/peppyMeter/pipe.zip
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.108.133, 185.199.110.133, 185.199.111.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.108.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 41181 (40K) [application/zip]
Saving to: ā€˜pipe.zip’
pipe.zip                          100%[===========================================================>]  40.22K  --.-KB/s    in 0.006s
2021-02-23 19:49:18 (6.38 MB/s) - ā€˜pipe.zip’ saved [41181/41181]
bash-5.0# mkdir pipe
bash-5.0# miniunzip pipe.zip -d ./pipe
MiniUnz 1.01b, demo of zLib + Unz package written by Gilles Vollant
more info at http://www.winimage.com/zLibDll/unzip.html
pipe.zip opened
 extracting: UIConfig.json
creating directory: asound/
 extracting: asound/volumioPeppyalsa.postPeppyalsa.5.conf
 extracting: config.json
 extracting: config.txt.tmpl
creating directory: i18n/
 extracting: i18n/strings_en.json
 extracting: index.js
 extracting: install.sh
 extracting: package.json
 extracting: peppy.service
 extracting: peppy.service.tar
 extracting: peppymeterinvolumio.png
 extracting: readme.md
 extracting: uninstall.sh
bash-5.0# cd pipe
bash-5.0# volumio plugin install
This command will install the plugin on your device
/usr/local/bin/volumio: line 259: /usr/local/bin/node: No such file or directory
bash-5.0#
Now it ends
Any idea??
I’m sending log report
info: Cannot send bug report: Error: Command failed: /usr/local/bin/node /volumio/logsubmit.js 'Sending log report, please wait'
/bin/sh: 1: /usr/local/bin/node: not found
After that I executed the installation as volumio
This is the live log:
pam_unix(su:session): session closed for user root
info:
---------------------------- MPD announces system playlist update
info: Ignoring MPD Status Update
info:
---------------------------- MPD announces state update: player
info: ControllerMpd::getState
info:
info:
info: ------------------------------ 7ms
info: sendMpdCommand status took 6 milliseconds
info: ------------------------------ 6ms
info: sendMpdCommand status took 3 milliseconds
info: sendMpdCommand playlistinfo took 2 milliseconds
info: ControllerMpd::pushState
info: CoreStateMachine::syncState   stateService play
info: CoreStateMachine::syncState   currentStatus play
info: Received an update from plugin. extracting info from payload
info: ------------------------------ 41ms
info: ------------------------------ 40ms
51.15.51.26 local addr 192.168.0.55 ->
What version of Volumio are you on? Seems to be an older beta version…
Edit: just went up and had a look at the steps you performed. It won’t work as the buster/alsa-pipeline branch has been deleted from Branches Ā· volumio/Volumio2 Ā· GitHub. So there isn’t a simple way to run this this on the 3.015 image.
Unfortunately you can’t switch to either the buster/master or buster/dev without performing more surgery to update to node v14.
I would recommend waiting for a new Buster beta image that is Coming Soonā„¢ :wink:
OK, I’ll try V2 right away.
Is my installation method ok?Schermafbeelding 2021-02-24 om 12.48.57
Not sure that is going to help – I believe @balbuze advises again using v2 as it’s quite complicated to get working Install peppy meter in volumio - #84 by balbuze
If you really want to get things working on v3.015 you can try something like this (it is most probably going to break things, but hey :wink: )
# Stop volumio
volumio vstop
# Update Volumio backend
cd /volumio
git fetch --unshallow
git branch -vv
git pull
git reset --hard d7a5678
# Check last 5 commits to see if we have all the right fixes
git log --no-pager -5
# Now switch to current buster branch
volumio pull -b "buster/master"
# Update the node_modules
rm -rf /volumio/node_modules
curl -L https://repo.volumio.org/Volumio2/node_modules_arm-14.15.4.tar.gz | tar xz -C /volumio
# Now update to node v14
# Remove node v8
sudo apt -y purge nodejs
cp /etc/apt/preferences.d/nodejs ~ # Back up our nodejs pin
sudo apt update && apt install  nodejs
# Cross your fingers and restart volumio
volumio vstart
Thx mate :+1:
First I’ll try V2.861 (updated to V2.873)
I’ll post the results (I had troubles with it as well).
Then I’ll try your method.
Keep you informed.!
Schermafbeelding 2021-02-24 om 13.14.00
volumio@vtest:~$ cd /volumio
volumio@vtest:/volumio$ volumio pull -b ā€œbuster/alsa-pipelineā€
Stopping Volumio
[sudo] password for volumio:
Backing Up current Volumio folder in /volumio-current
Cloning Volumio Backend repo
Cloning branch buster/alsa-pipeline from repository
fatal: repository ā€˜ā€™ does not exist
Copying Modules
cp: cannot create directory ā€˜/volumio/node_modules’: No such file or directory
Copying UI
cp: cannot create directory ā€˜/volumio/http/www’: No such file or directory
Copying Volumio3 UI
cp: cannot create directory ā€˜/volumio/http/www3’: No such file or directory
Getting Network Manager
/volumio/app/plugins/system_controller/network/wireless.js: No such file or directory
Setting Proper permissions
chown: cannot access ā€˜/volumio’: No such file or directory
chmod: cannot access ā€˜/volumio/app/plugins/system_controller/network/wireless.js’: No such file or directory
Pull completed, restarting Volumio
Done
Hmm doesn’t look like a good start…
Volumio directory is gone :weary:
Please tell me what I did wrong?
Next:
Schermafbeelding 2021-02-24 om 14.02.38
Fresh installation with touch-display plugin installed and working fine (on hdmi).
It doesn’t like: git log --no-pager -5
Schermafbeelding 2021-02-24 om 14.21.17
With this: curl -L https://repo.volumio.org/Volumio2/node_modules_arm-14.15.4.tar.gz | tar xz -C /volumio
I get a long list of:
Seems not to work.
Ok, installed again, on clean V2.861 (not updated), only touch-display plugin installed.
Here is what’s happening: Again the volumio-directory is gone after: volumio pull -b ā€œbuster/alsa-pipelineā€
It was there before issuing the command (I checked)
There must be something wrong in the script, I think.
The git command should be git --no-pager log -5 but it’s just a check, so you can skip it.
After the volumio pull command, confirm if you are on the right branch with
cd /volumio
git branch -vv
For the node_modules you might need a sudo or you can change permissions with sudo chown $USER:$USER /volumio
I needed sudo for all commands.
Yes - as I mentioned a few posts up - that branch has been deleted - it wont work… It will just fetch master and that will not work…
That’s why I asked if my installation method was OK.
Could you give me a list of the exact commands to issue on V2.861, please?
I wouldn’t know sorry :slight_smile:
OK, no problem.
Thx for the help anyway.
I hope balbuze can take a look at this, soon.
Really, it would be really a good idea to wait for next beta (next week???). No need to tweak such things… Be patient :wink:
At least me I am patient because I am waiting an extender micro sd card from Ali express :slight_smile: I have my own working peppy on v 2.853 by I have forget all if I need to install it again :smiley:
I hate waiting… :stuck_out_tongue_winking_eye:
Working
Well done​:+1::wink:
Thx :+1:
The meters are located top left on the screen.
Do you have any idea where I can alter the placement on the screen?
Or can I start them in a xsession?
