I have succeeded. Thank you very much for your help.
Now I have to fix the peppymeter errors.
I have made the changes you suggest in the configuration file, but I don’t see anything on the screen. Could you send me the changes made in your peppymeter.py file?
Another question … how do you run it? I see several options
This is a great topic as I am trying to make PeppyMeter showing up on my 7" display running Volumio.
I’ve submitted the fix for peppyalsa building failure. From now on, it should build smoothly without using CFLAGS.
Meanwhile I wonder if there is a github repo on how to integrate PeppyMeter to Volumio? It doesn’t need to be fully working plugin, just the config files as well as the steps, described by @Lintbf and @Mstislav?
If not, I will be more than happy to create one and hopefully this community can collaborate? Maybe if time permits, we can work together to create the plugin. It’ll really cool to have PeppyMeter plugin for Volumio.
hello,
Just an info…
We are working on a new architecture for alsa in volumio.
I already adapted some plugins to work with it. I also started some new plugins, one is peppyalsa…
At this point, it configures volumio to output to pipe to peppyalsa, provided by the plugin. It clones peppymeter too. It works for all sources. It is not ready yet for publishing, but don’t waste time to write something for the current volumio…
Hello colleagues,
I am so glad that this in the end will be e plugin :), because I have spend 2 3 days on make it worked. With help of volumio users and creator of peppymeter volumio . It looks so great.
But the main issue will be I believe, if I will upgrade the volumio I do not think I can install it again. But I have wrote all the steps…
I know that it is an issue with dsd files when peppymeter plugin is active. I guess 2 pipes needs to be configured. I could not make it… This will also be fixed?
Thanks.
I have installed peppyalsa but not peppymeter. I have been a few days dedicated and I have decided to give myself a few days to rest from the installation. This matter has come to frustrate me!
I hope that with the good news of this new plugin I will have the opportunity to make it work.
At this point, it is just a basic pipe. I don’t know for dsd file what is required. We’ll see later
edit : Do not hesitate to gives your tips to get it work!
Peppymeter plugin would be the best!
step by step
and don’t trip over your peppy only step by steppy…
Hello!
A first version of PeppyMeter plugin is out!
It requires testing
You need a Buster version with modular_alsa enabled and other fixes (node path, etc).
You need touch_display installed
Once ready, just install the plugin, enable and… that’s it!
Tested only with RPI4 + official 7"
The link : https://github.com/balbuze/volumio-plugins/tree/alsa_modular/plugins/audio_interface/peppyalsapipe
is this running on 3.10 @balbuze ? getting errors…
This command will install the plugin on your device
Compressing the plugin
No modules found, running “npm install”
/bin/sh: 1: /usr/local/bin/npm: not found
Error installing node modules: Error: Command failed: /usr/local/bin/npm install --production
/bin/mv: cannot stat ‘*.zip’: No such file or directory
child_process.js:650
throw err;
Error: Command failed: /bin/mv .zip /tmp/plugins/peppyMeter.zip
/bin/mv: cannot stat '.zip’: No such file or directory
at checkExecSyncError (child_process.js:607:13)
at execSync (child_process.js:647:13)
at install (/volumio/pluginhelper.js:689:9)
at Object.<anonymous> (/volumio/pluginhelper.js:751:9)
at Module._compile (module.js:653:30)
at Object.Module._extensions..js (module.js:664:10)
at Module.load (module.js:566:32)
at tryModuleLoad (module.js:506:12)
at Function.Module._load (module.js:498:3)
at Function.Module.runMain (module.js:694:10)
volumio@music:~/pipe$
Tested in 3.014 only…
before trying, you need to
Disable plugin such as equalizer if any and
sudo ln -s "$(which node)" /usr/local/bin/node
sudo ln -s "$(which npm)" /usr/local/bin/npm
sudo ln -s "$(which npm)" /bin/npm
and modular_alsa enabled
cd /volumio
volumio pull -b dev/buster/alsa-pipeline https://github.com/timothyjward/Volumio2
cd ..
cd /volumio
nano .env
and change lines
WRITE_MPD_CONFIGURATION_ON_STARTUP=true
MODULAR_ALSA_PIPELINE=true
and restart
volumio vrestart
and
You have to be root
su
echo ‘/opt/vc/lib’ >/etc/ld.so.conf.d/00-vmcs.conf
and
/sbin/ldconfig
Installing is long because it needs to compile peppyalsa. Be patient… But when the plugin appears in UI, it is ready!
@balbuze asla seems to fail after it all can’t play songs any more…
su
and
/sbin/ldconfig
seems to end on bash-5.0#… pasted the text in it …
btw the 3.10 seems to be a bit diffirent then the 3.14
Have you enabled modular_alsa?
Have you sound with the plugin desactivated?
what is /etc/asound.conf ?
at the moment i have no sound any more how to enable modular_asla installed it …
pcm.!default {
type copy
slave.pcm "volumio"
pcm.volumio {
type copy
slave.pcm "volumioPeppyalsa"
pcm.volumioPeppyalsac {
type lfloat
slave.pcm "volumioPeppyalsac"
slave.format "FLOAT"
pcm.volumioPeppyalsa {
type meter
slave.pcm "postpeppyalsa"
scopes.0 peppyalsa
pcm_scope.peppyalsa {
type peppyalsa
decay_ms 400
meter "/tmp/myfifopeppy"
meter_max 100
meter_show 1
pcm_scope_type.peppyalsa {
lib /usr/local/lib/libpeppyalsa.so
pcm.postpeppyalsac {
type lfloat
slave.format "S24_LE"
pcm.postpeppyalsa {
type copy
slave.pcm "postPeppyalsa"
pcm.postPeppyalsa {
type copy
slave.pcm "volumioOutput"
# There is always a plug before the hardware to be safe
pcm.volumioOutput {
type plug
slave.pcm "volumioHw"
pcm.volumioHw {
type hw
card 3
This seems ok!
Can you check if peppyalsa is well compiled/installed ?
ls /usr/local/lib/libpeppyalsa.*
can not access ```
it's not there only python 2.7 & python 3.7 and 2 libsox files
