Install from fresh download
hi all
I just the downloaded the latest version, unzipped it, burned the .img file to an SD card and booted up my raspberri pi + hifiberry DAC with it.
But the volumio android app is not picking it up; what I can see when I plug in a HDMI cable, is that the system boots and allows me to login as user volumio.
Is this a sign that something already went wrong?
Or what can I do after logging on to get the Android app to notice the new installation?
regards, Danny.
ok, thanks, that 192.168.211.1 got things going for me.
But it might be worthwhile to mention this intermediate wifi connection on the main website, right where it says
*Download the Android or iOS app from the relevant store.*
  • Select “Configure a new Device” and follow the guided setup*
regards, Danny
i’m just a member like you so i can’t do that.
best regards,
dvo
ok… thanks anyway for your help, and let’s hope that someone with sysadmin rights picks this up :slight_smile:
For me it’s a broken link and not a solution.
Yeah happens if you bump old topics.
Instructions are on the same page as where you’ve downloaded the image.
fixed it :slight_smile: you can use the link again.
