Install Docker Compose on Volumio
I managed to install Docker and build and run containers but I would also like to install Docker Compose on my Volumio image. There are no issues when installing libffi-dev, libssl-dev, python3-dev, python3 and python3-pip packages. But installing docker-compose with pip3 throws an error:
sudo pip3 install docker-compose
Downloading/unpacking docker-compose
Downloading docker_compose-1.29.2-py2.py3-none-any.whl (114kB): 114kB downloaded
Downloading/unpacking requests>=2.20.0,<3 (from docker-compose)
Downloading requests-2.26.0-py2.py3-none-any.whl (62kB): 62kB downloaded
Cleaning up…
Exception:
File “/usr/lib/python3/dist-packages/pkg_resources.py”, line 2595, in _dep_map
return self.__dep_map
File “/usr/lib/python3/dist-packages/pkg_resources.py”, line 2457, in getattr
raise AttributeError(attr)
AttributeError: _DistInfoDistribution__dep_map
During handling of the above exception, another exception occurred:
File “/usr/lib/python3/dist-packages/pip/basecommand.py”, line 122, in main
status = self.run(options, args)
File “/usr/lib/python3/dist-packages/pip/commands/install.py”, line 290, in run
requirement_set.prepare_files(finder, force_root_egg_info=self.bundle, bundle=self.bundle)
File “/usr/lib/python3/dist-packages/pip/req.py”, line 1266, in prepare_files
req_to_install.extras):
File “/usr/lib/python3/dist-packages/pkg_resources.py”, line 2401, in requires
dm = self._dep_map
File “/usr/lib/python3/dist-packages/pkg_resources.py”, line 2597, in _dep_map
self.__dep_map = self._compute_dependencies()
File “/usr/lib/python3/dist-packages/pkg_resources.py”, line 2621, in _compute_dependencies
parsed = next(parse_requirements(distvers))
File “/usr/lib/python3/dist-packages/pkg_resources.py”, line 2721, in parse_requirements
“version spec”)
File “/usr/lib/python3/dist-packages/pkg_resources.py”, line 2686, in scan_list
raise ValueError(msg, line, “at”, line[p:])
ValueError: (‘Expected version spec in’, ‘charset-normalizer ~=2.0.0’, ‘at’, ’ ~=2.0.0’)
Has anyone managed to install Docker Compose on Volumio somehow? Would it be a better approach to start from Raspbian and run Volumio in a Docker container? I have found a popular image jbonjean/volumio but it is for x86, not ARMv7.
Volumio Information
Volumio Version: 2.907
Hardware: Raspberry Pi 3 Model B Rev 1.2
DAC: HiFiBerry AMP2
Greetings!
I still have a problem with installing Dicker on
PiZero W v1.3
Volumio v 2.907 02/07/2021 (last)
( uname -a: Linux volumio 4.19.118+ #1311 Mon Apr 27 14:16:15 BST 2020 armv6l GNU/Linux)
More description:
Hi, here is my procedure to successfully install docker, docker compose and portainer on Volumio 3
#####Install docker
curl -fsSL get.docker.com | CHANNEL=stable sh
sudo apt install docker-ce
sudo apt-get install docker-ce docker-ce-cli containerd.io
##### configure docker user & group
sudo groupadd docker
sudo usermod -aG docker $USER
newgrp docker
##### Configure Docker to start on boot
sudo systemctl enable docker.service
sudo systemctl enable containerd.service
##### Install portainer
docker volume create portainer_data
docker run -d -p 8000:8000 -p 9443:9443 --name portainer \
--restart=always \
-v /var/run/docker.sock:/var/run/docker.sock \
-v portainer_data:/data \
portainer/portainer-ce:2.9.3
Within portainer accessible at http://volumioip:9443, you can use “stacks” to manipulate docker-compose 3 scripts the very easy way
Hello.
Forgive my boldness, but I would like to ask you if you can explain to a newbie (me) the complete procedure to install Volumio and Pihole together on an RPI 4, with Docker or with the procedure that you think is best.
My Linux knowledge is limited, and I’ve been trying to get it to work for quite some time, but I can’t.
I know that what I’m asking of you involves a lot of work, but I don’t know how to do it.
Thanks in advance.
Keep in mind that running Volumio in a docker is not supported.
OK, and docker in Volumio, and Pihole inside docker?
Still not supported by Volumio
Bad news :neutral_face:
Anyway Volumio + RPI4+Allo Bos DAC, it is a great way to listen to almost perfect music.
Thanks a lot
