Install Baikal on Volumio
I’m wondering if there is a possibility to install Baikal (sabre.io/baikal/) on Volumio on raspberrypi (or some caldav server like it). I had it running on an raspberrypi with an nginx webserver, but so far couldn’t find any way to configure the webserver in volumio.
Do you guys have any suggestions on how to do this?
best rergards!
What is Baikal?
It’s a small carddav/caldav server i use to manage my calendars and adressbooks.
sabre.io/baikal/
It simply needs a running webserver (like nginx), but i couldn’t find the location of the weberver in volumio?
We don’t have any webserver on Volumio (like nginx) because Volumio is doing its webserver by himself (via express). Furthermore, if you install nginx or any other webserver, volumio will stop working
oh damn it… guess 'll have to think of another solution then… :confused:
thanks anyway!
