mpd.conf ist autogenerated and users shall use the mpd section of the web adminstration.
Unfortunately I didn’t find an entry for the max playlist length, which seems to be 16384 by default .
I just wonder how I can increase the max_playlist_length ?
Not sure if this is an issue for anybody else, however my library is >90,000 tracks and I typically dump the whole thing onto the playlist with random enabled. Works, however it would be great to have the upcoming songs listed on the playlist tab. Any chance of doing it the same way it works with Daphile? Shows the next 10 or so tracks and then continuously removes songs as they are played and adds more to the list as you go…
