i want to change the volume of my volumio via a tcp or http command. i’ve found http-commands-requested-t1822.html but there i can only set a specific value. what i would like to do is “increase by 5” or something like that. is that possible?
thank you! cheers, tom
Noone?
Gesendet von iPad mit Tapatalk
You should have looked more closely to the page you were looking at:
manpages.ubuntu.com/manpages/luc … mpc.1.html
This gives the following info:
volume [±] Sets the volume to (0-100). If “+” or “-” is used, then it adjusts the volume relative to the current volume.
You should be able to adapt this to your need
