A form of this type of problem was reported previously on several occasions but unlike those situations the issue occurred here only after I tried Audio Resampling on my Rivo+. I’m using a Topping D90SE DAC (it accepts native DSD). The Rivo+ is connected to the Topping D90SE via I2S. I’m using PS Audio (as recommended) for the HDMI I2S Mode.
Prior to trying Audio Resampling, the PCM and DSD resolutions were properly displayed on the DAC. After trying resampling, switching back to the native bit depth and sample rate, turning Audio Resampling off and saving the settings, the PCM resolutions were properly displayed but DSD (2.8MHz) displayed as PCM without any sampling rate being shown.
This suggests that the Rivo+ no longer recognizes the D90SE as being able to accept native DSD and may be sending DSD via DOP. However, the failure to show the sampling rate potentially suggests the problem may be more than just the DSD transfer mode. Switching to DSD over DOP did not resolve the issue. Even then DSD was not displayed and playback resulting a cracking sound.
There are no settings in the DAC that would affect this. Is there a way to resolve this issue other than a factory reset, or is that now my only option?
In that regard I noticed that the instructions for the factory reset in the Rivo+ on-line manual indicate that the link for downloading the factory reset file is: http://repo.volumio.org/**Primo**/factory_reset. Shouldn’t that be Rivo+ rather than Primo? Substituting Rivo+ for Primo in the URL results in the “404 Not Found” response. Concern about the accuracy of the link makes me hesitant to try the Factory reset option in the Rivo+ settings.
Any help or advice would be greatly appreciated. Thanks.
