Hi, I’m all new user and I have lot of problems, thank you for your help.
On “volumio.local”, my audio out is USB and I can’t select it (only “Cheapo Audio Jack”, or “HDMI audio out”, or last “Cheapo S/PDIF” on 2 lines… why ???
I have a Pro-Ject Pre Box S2 Digital with an audiophile USB cable connected to the USBridge and impossible to select it…
Hello again, i answer to myself, i’ve not plugged pro-ject DAC on 220v, now that’s okay (before my USBdrive the pro-ject had not 220v, the USB port of my macbook air was sufficient).
I’ve another question : the DSD music is jerky… USBdrive cannot manage this type of BIG file or can I change my settings ?
Hi Vincent,
I presume you are using the latest Volumio image version, correct?
Have you tried the Pro-Ject connected directly to another USB port of the USBridge?
Any difference?
Another suggestion, as this concerns the USBridge, is I move this topic to the DAC section, OK?
This is where the Allo people also answer if anything particular pops up with the USBridge.
The Pro-Ject / USBridge is not a common configuration, they might be able to help.
