Will it affect sparky users? We got a very welcome but supposedly unsupported 2.882 update here:
My allo usbridge is working perfectly ever since, including tidal connect, local (dlna) playback and most web radios. But web radios have been shaky lately…
Hi
I’ve got the miniDSP.
I’m experiencing some troubles with the connexion to Tidal. Altough I enter the credentials I can’t get connected. Spotify connect works well. My version is 1.099 if I check for updates it appears to be the last one. Could you please indicate a way to connect?
By the way, is there an approximate date to be able to use the Tidal connect with the miniDSP?
Thanks and regards
Yes, sorry I was a little fast.
I’m experiencing dropouts, in the way that I have to reconnect to Volumio Tidal Direct in the Tidal app. The connection just disappears and the music stops. The Volumio device is however always present when I reconnect.
I’ve been very pleased with the Tida Direct feature, and it has been working flawlessly. I started experiencing dropouts about 2-3 weeks ago. I’ve changed my router I’m hope of a fix. So when I got you news mail today, I was eager to try it out.
But as you can understand I still have dropouts.
PS. It’s been playing fine for about 2 hours strait now
Regards Mikkel
Got my mini dsp shd studio today and even with the update i‘m not able to login into tidal… bad bad… i sold my cocktail audio because of this and now it continues…
All our OEM partners received the emergency update. So if you are using a product from one of our official OEM partners, then just update and you’ll be fine
I had “Spotify plugin for Volumio2”
“Volumio Spotify Connect2” and
“Radio Paradise”. There are no special mods. Other than a HifiberryDAC.
Did a fresh install with those plugins and everything is working as it should
Hi, I had to install my player from scratch ,because I am running two Python programs in Volumio environment (MPD_OLED, shuttdown procedure on button). The updater refuses update if it finds some changes. Is it necessary upgrade whole Volumio due to certificate expiration?
PB
