after installing Volumio I found the hardware volume control to be already selected and to work, but at 100% sounded too loud to be true, so I disabled volume control. When I activated HW control again, I found that volume controls (just like in RaspyFi) the basses, not the volume!
What should I correct and where? I have no experience with ALSA (or what you are using).
I have the exact same issue.
Weird fact: this is my 2nd install after i screwed the first time up. initial try I didn’t have this issue.
If i set the playback device to system volume control works, but I would like to use alsamixer to pump up the bass a bit
Which DAC do you guys use?
griffin iMic
Hello please Check out here. I found a Solution for the topic:
- "Hardware Volume Knob controls Bass Boost and
- Too much Bass after reboot because alsamixer bass boost is enabled by /home/volumio/unnute.sh
https://volumio.org/forum/volumio-and-usb-imic-too-many-basses-t2856.html
Best Regards
