Igel H700C
I am trying to install Volumio on a Igel H700C barebone (Via C7, 1Gb Ram and chipset Via Chrome C9). [Sound card is PCI M-Audio Audiophile 24/96]. I have seen similar systems on the compatibility thread ( compatible-x86-machines-t6301-20.html )
I have limited linux experience.
The PC boots, but the graphics system fails and I can not setup volumio and wifi.
Any advice is welcomed.
Thank you,
Jorge.
Hi Jorge,
PC boot’s? Can you find a wlan with ssid ‘volumio’ from another device? If yes, its fine. connect and go for volumio.local.
volumio.github.io/docs/User_Man … tart_Guide
good luck
Thank you. It is working fine. (I should have read the manual)
:wink:
