Using a RPi 3 Model B v1.2 with the newest Volumio installed, sadly, my brand new ifi iDSD Nano Black Label is not recognised. When i plug it in nothing happens. I still have the same 2 Options for playback setting: HDMI/Audio Jack.
Output of lsusb -t:
volumio@volumio:~$ lsusb -t
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc_otg/1p, 480M
|__ Port 1: Dev 16, If 0, Class=Hub, Driver=hub/5p, 480M
|__ Port 1: Dev 17, If 0, Class=Vendor Specific Class, Driver=smsc95xx, 480M
|__ Port 2: Dev 18, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 2: Dev 18, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
volumio@volumio:~$
Yes, there are connection errors on the usb port, the same in both situations:
Oct 11 12:15:06 volumio kernel: usb 1-1.5: new high-speed USB device number 4 using dwc_otg
Oct 11 12:15:06 volumio kernel: usb 1-1.5: device descriptor read/all, error -32
Oct 11 12:15:06 volumio kernel: usb 1-1.5: new high-speed USB device number 5 using dwc_otg
Oct 11 12:15:06 volumio kernel: usb 1-1.5: device descriptor read/64, error -32
Oct 11 12:15:06 volumio kernel: usb 1-1-port5: attempt power cycle
Oct 11 12:15:07 volumio kernel: usb 1-1.5: new high-speed USB device number 6 using dwc_otg
Oct 11 12:15:07 volumio kernel: usb 1-1.5: device descriptor read/8, error -32
Oct 11 12:15:07 volumio kernel: usb 1-1.5: new high-speed USB device number 7 using dwc_otg
Oct 11 12:15:08 volumio kernel: usb 1-1.5: device descriptor read/8, error -32
Oct 11 12:15:08 volumio kernel: usb 1-1-port5: unable to enumerate USB device
Did you try another port?
Do you have the possibility to try with a powered usb hub?
Can you try with another usb cable?
You may have to try a male-to-male usb cable to connect to the other ports
I have seen these issues being reported on PI 3 before, not sure if can help.
