Hi all,
thanks in advance for any pointers. I’m trying to work out why some of my devices lag spectacularly when controlling volumio wirelessly. I’ve got a server with a samba share serving up FLACs connected via a cat6 network to my Pi4 which is only running volumio. If I use my iPhone 11 to access volumio then everything is perfect, I can scroll albums and controls react instantly. However, if I use my iPad Pro or MacBook Pro to control volumio then the artwork loads so slowly that it makes navigating impossible and the lag on play/pause/other interactions is awful. All three devices are connecting to the same network wirelessly, all have excellent wifi throughput when I look up their connection stats (e.g., the MacBook Pro currently has a tx of 1300 Mbps and rx of 24 Mbps reported at the router) and yet two of them lag - any ideas what I can do to fix this? Can’t work out why one device is flawless whilst the others (with similar if not better wireless connection) are unusable. Doesn’t matter if I use the IOS app either.
Thanks again
Volumio Information
Volumio Version: v2.907
Hardware: Pi4 4gb
DAC: allo digiOne
