I want to use the i2S outputs from my Raspberry Pi B+ to connect to my Minisharc DSP.
the IQAUDIO dac i have works perfectly, but I want to connect the pi to the Minisharc with i2s
so far using the Volumio default I2s DAC setting and also the Hifiberry DAC I can get the pin to play music files, however all i get it white noise.
am using the correct pins for the i2s outputs from the pi. using my DMM on the frequency setting shows 44.1khz on LRCK and i have a clock signal from BCLK, but my DMM is out of range for whatever the frequency is.
does anyone have any sugestions of what I can try next?
Brad
