Hello Volumians,
I have set up a Raspberry Pi 0 W using the latest version of Volumio (2.285). And I have added a DAC, the Adafruit I2S 3W Stereo Speaker Bonnet for Raspberry Pi https://www.adafruit.com/product/3346
So, I have turned on the setting in Playback Options for I2S Dac (ON), but I cannot determine how I should set the other options. There is no specific choice for “Adafruit I2S 3W Stereo Speaker Bonnet”. I have tried to select various settings in this section and the result sometimes crashes and reboots the raspi, or alternatively just does nothing.
What should i select for Output Device?
What should i select for DAC Model?
Should I change other Playback options such as DSD Playback mode?
thanks for your help,
Neil
PS: I did do some testing and I am able to run sound through the DAC and hear it from the speakers using the following commands. These all work fine:
Simple white noise speaker test
speaker-test -c2
Simple WAV speaker test
speaker-test -c2 --test=wav -w /usr/share/sounds/alsa/Front_Center.wav
Simple MP3 speaker test
mpg123 http://ice1.somafm.com/u80s-128-mp3
