I’m making a fresh install of volumio on my odroid C2.
I want to use some of my python scripts again which use the I2C bus.
I had I2C working on an older version of volumio without any problem.
But now I don’t get it running again. I don’t understand what I’m doing wrong.
Strange, /dev/I2c-1 works out-of-the-box, we use it to drive the HiFi Shield 2 DAC, always been like that.
Use i2cdetect before you install anything new, i suspect you might be overwriting something.
I downloaded the 14 april 2018 version of volumio and installed it.
I directly looked into the dev folder.
There is still no /dev/i2c-1 file.
In the older version of volumio I know this file was there.
Trying i2cdetect returns
volumio@volumio:/dev$ i2cdetect -y -r 1
-bash: i2cdetect: command not found
Selecting the hifishield/shield+ in settings playback options doesn’t make a difference.
I noticed that it is not possible to select hardware mixer type at settings volume options.
Maybe because I2C isn’t working.
I don’t know of it matters that I don’t use the orginal hifi shield. But that has never been a problem
with the older volumio version.
HiFi Shield and HiFi Shield + do not use i2c, only Shield 2 does.
I’ll have a closer look to a freshly started odroid c2 and come back with notes to compare.
i2cdetect is not available by default
To install sudo apt-get update
sudo apt-get install i2c-tools
It would also help if you could do a log for me.
To create a log: go to the volumio.local/dev page, fill in the description and send.
A URL will be returned after a few seconds, I need that one so I can have a look.
You will get a PM with an email address to send the URL to.
Can we follow up in the Community Portings, Volumio on Odroids section please?
Edit: This topic is now continued in the Community Portings
