not sure if Volumio related or not but i am using the new tinkerboard image and the Raspberry pi 7" touchscreen there is a odd error in the main terminal window… the display works but no touchscreen component
I am using the latest volumio image for tinkerboard
As soon as i unhook the display from the mipi dsi conector and hook up a hdmi monitor the constant stream of errors goes away
rk3x-i2c ff150000.i2c: flags from: 0, 1, addr: 0x38
So far it hasn’t affected performance of it just a nuisance till the kiosk window opens
Tim
