Hello. I’m new to Volumio and I have a couple of questions about it. I have average Linux knowledge, mainly in Debian based OSes. This post involves some small suggestions but because I can’t choose a multiple categories at once, just ignore it. Also it has some micro bug reports.
Sorry if there are any grammar mistakes. English isn’t my first language.
Here are a few things that are (probably) good to know:
- I’m running Volumio on a Raspberry Pi 4B (2GB Memory)
- I have a GPIO attached LCD touchscreen attached to it
- I’m downloading Volumio OS from the Raspberry Pi Imager. (rpi-imager 1.7.4 - Volumio Release 2023-2-7)
- I have a Waveshare 3.5" LCD (B) revision 2
Here are my simple (probably dumb) questions:
- Where am I supposed to drop music and import it into Volumio?
- How do I change the keyboard layout and keep it after a reboot? Or better, how can I get the keymap to apply at all? (I actually spent 2 hours trying to set it with literally EVERY method of changing the keymap)
Here are my more advanced questions:
(Expand Me, Long) - How to display the WebUI on my LCD?
Here’s what I tried:
apt install chromium-browser xorg
-Fails (unmet dependencies, broken packages)
apt install firefox-esr xorg
-(Doesn’t really work) Succeeds (Installs and runs fine, can’t access volumio.local or localhost) (Not really an issue with Volumio: when using the Waveshare LCD driver, xorg doesn’t detect the framebuffer, Fails)
Info I gathered:
- Firefox was (so far) the closest to working. I guess some sign of firewall was blocking localhost connections? But what kind of firewall would do that…
- Chromium doesn’t even try to install. (Tried literally every method that I know of to fix broken packages)
Possible solution(s):
- Add a feature that will show the WebUI on boot on all monitors attached. (Could be a setting in volumio-config {More on volumio-config later})
(Not really about Volumio, Expand Me, Short) - Getting the WebUI displayed on the LCD
As I mentioned earlier, I have a Waveshare 3.5" LCD (B) revision 2. It attaches to the Pi via GPIO pins. It uses the SPI protocol to send frames over to it. Here is a link to a GitHub repo that has all of the Waveshare drivers (I have the LCD35B-show-V2 driver)
It would be nice if you would help me guys!
About volumio-config, I will (probably) write a suggestion for it with all of the neat features it could have. Of course, the devs can totally reject my idea. I understand that maintaining an OS is hard and that’s why I want to thank the developers of Volumio for all of their hard work.
