I am running the autostart plugin. Every time volumio boots up. It plays just as it should then 30 seconds later it quits playing and says configuration updated, system restarted.
Why??? So f#$%king frustrating.
This happens on more than one device as i have 4 of them
I guess autostart plugin starts too early, before the boot process end…
Hi @jocoman ,
Please experience with the time setting in de settings. I have mine set to 60000.
ok, that worked , thanks
I’m still getting this constantly. I’ve reformatted and reinstalled multiple times. How do I change this setting to see if that will resolve my issue? Thanks in advance.
it’s just a setting in the auto-start plugin
In addition to the continuous ‘Configuration Update’ loop, when I go to Plugins it tells me I have to be signed into My Volumio. I go to my account and it shows me signed in with Premium account and it shows MyVolumio activated on my device. This is happening on the latest version of Volumio on a Raspberry Pi 4 with HifiBerry DAC2 Pro connected via Ethernet cable. I just sent a log report, so hopefully you can tell me what I can do to get this running. This issue has been going on for a while. Thanks in advance.
Please paste the link to the log here, otherwise we have no clue which log is what.
Please got to myvolumio and delete your device and reboot.
Sorry about that. Here you go.
You have a network error, hence the continuous reboot.
Please try to boot with a cabled connection and check your DNS.
You can set the DNS in volumio.
use
8.8.8.8
8.8.4.4
Jan 23 04:38 : client: [0] opened from local
Jan 23 04:38 : exception: No such directory
Jan 23 04:38 : client: [1] opened from local
Jan 23 04:39 : zeroconf: No global port, disabling zeroconf
Jan 23 04:39 : client: [0] opened from local
Jan 23 04:39 : exception: No such directory
Jan 23 04:39 : client: [1] opened from local
Jan 23 21:23:13 volumio volumio[32351]: |||||||||||||||||||||||| WARNING: FATAL ERROR |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Jan 23 21:23:13 volumio volumio[32351]: Error: getaddrinfo -3007
Jan 23 21:23:13 volumio volumio[32351]: at errnoException (/volumio/node_modules/mdns/lib/resolver_sequence_tasks.js:199:11)
Jan 23 21:23:13 volumio volumio[32351]: at getaddrinfo_complete (/volumio/node_modules/mdns/lib/resolver_sequence_tasks.js:112:10)
Jan 23 21:23:13 volumio volumio[32351]: at GetAddrInfoReqWrap.oncomplete (/volumio/node_modules/mdns/lib/resolver_sequence_tasks.js:120:9) {
Jan 23 21:23:13 volumio volumio[32351]: code: -3007,
Jan 23 21:23:13 volumio volumio[32351]: errno: -3007,
Jan 23 21:23:13 volumio volumio[32351]: syscall: 'getaddrinfo'
Jan 23 21:23:13 volumio volumio[32351]: }
Jan 23 21:23:13 volumio volumio[32351]: |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Enabling the Custom DNS server seems to have fixed the issue. I really appreciate your help.
