I’ve got a Pi 4 and volumio v2 and its pretty great. Only one small issue which I am thinking is network settings related. I have to restart my pi by unplugging and re-plugging every time I want to connect to the volumio device. Is there something I can change to keep it connected all the time?
Cheers
Could you share some logs?
Either a link to a full debug log or a quick snippet from the /dev
page using the livelog feature or via ssh.
# Volumio logs
journalctl -f
# vollibrespot logs
journalctl -f -o cat -u volspotconnect2.service
Note you might need sudo
before these commands depending on the version of Volumio your running
Ideally you would do this when said you are facing the issue
Here is the log. It is a live log. I’m on a mac and was having trouble figuring out how to log any other way. It will just randomly stop playing. The only way I can get it to reconnect is by powering the pi off and on.
http://logs.volumio.org/volumio/tvo8Ykn.html
additionally when it stopped playing I noticed the “seek” part was going up and up and up
It would be really nice to not have to unplug and replug this all the time. Thanks for all your help.
