I have a DAC to be used a Model B. Is it possible?
I got this cheap DAC to be used with my Raspberry Model B. Is it possible with the several pins in the DAC without connections.
Or should I return it?
Yes it is possible, but you will have to solder the 8 PIN „P1“ connector on the Pi and then use male to female jumper wires to connect it.
Don‘t expect top performance with this old Pi :slight_smile: - but it will work.
br
Josef
Do you have a guide about that, or at least a picture? I’m a beginner in the hardware side of the raspberry
Search is your friend :slight_smile: The pins should be similar to what you require.
https://pi4j.com/1.2/pins/model-b-rev2.html
