I get errors that say "failed to decode" and that "CURL failed: Resolving timed out after 10000 millieseconds"
Hi there,
I just setup everything on my Rasberry Pi4. iOS app working, local controls working etc. but I am unable to play anything. I get errors that say “failed to decode” and that “CURL failed: Resolving timed out after 10000 millieseconds”
Attached is my logs
http://logs.volumio.org/volumio/6BRo8Nj.html
Looks like your DNS settings are not working.
Did you set up Static IP address? If yes, disable it, you might have misconfigured it
Hi @volumio - I am not sure why that might be, I did a clean flash using balena and did not touch anything to do with IP address.
Is there an area in the settings I should be looking into?
Balena is known to cause problems with Volumio. Maybe try Raspberry Pi Imager.
Hi @SimonE - thanks for the suggestion. I just reflashed it with Raspberry Pi Imager, re-authenticated tidal and tried to play and it did not work either. Same error
@volumio - confirming in my wireless network settings I have “automatic IP” set to On and have not setup a customer DNS server, that setting is set to Off
@volumio - setting up a custom dns server fixed it!
Good to know. To which dns did you set? And where are you from and which ISP do you have?
I am in Melbourne, Australia. My ISP is Aussie Broadband.
