I’ve modified the c code in IQ_rot.c so that it updates the volume level in Volumio. I’ve included it below in case anyone is interested. I should however mention that it is not perfect and there is some lag in updating the UI.
Running the command “volumio volume” in cli takes some time to return a value. I wonder what causes the delay. I’ve added code to spawn a new process for updating the UI value so that it doesn’t block the main program.
I’ve also made sure that the rotary encoder is initially set to the actual volume level of Volumio instead of an arbitrary value.
Please let me know if anyone has any suggestion to improve upon this code.
Thanks.
[code]// Rotary Encoder Sample app - IQ_rot.c
// Makes use of WIRINGPI Library
// USES Raspberry Pi GPIO 23 and 24.
// Adjusts ALSA volume (based on Left channel value) up or down to correspond with rotary encoder direction
// Assumes IQAUDIO.COM Pi-DAC volume range -103dB to 0dB
// G.Garrity Aug 30th 2015 IQaudIO.com
// Compile with gcc IQ_rot.c -oIQ_rot -lwiringPi -lasound
// Make sure you have the most upto date WiringPi installed on the Pi to be used.
#include <stdio.h>
#include <wiringPi.h>
#include <alsa/asoundlib.h>
#include <alsa/mixer.h>
#include <stdbool.h>
#include <stdlib.h>
#include <errno.h>
#include <string.h>
Rotary encoder connections:
Encoder A - gpio 23 (IQAUDIO.COM PI-DAC 23)
Encoder B - gpio 24 (IQAUDIO.COM PI-DAC 24)
Encoder Common - Pi ground (IQAUDIO.COM PI-DAC GRD)
// Define DEBUG_PRINT TRUE for output
#define DEBUG_PRINT 0 // 1 debug messages, 0 none
// Define the Raspberry Pi IO Pins being used
#define ENCODER_A 4 // GPIO 23
#define ENCODER_B 5 // GPIO 24
#define TRUE 1
#define FALSE 0
static volatile int encoderPos;
static volatile int lastEncoded;
static volatile int encoded;
static volatile int inCriticalSection = FALSE;
/* forward declaration */
void encoderPulse();
int main(int argc, char * argv[])
int pos = 125;
long min, max;
long gpiodelay_value = 250; // was 50
snd_mixer_t *handle;
snd_mixer_selem_id_t *sid;
const char *card = “default”;
// Previous linux driver’s mixer name
// const char *selem_name = “Playback Digital”;
// const char *selem_name = “PCM”;
const char *selem_name = “Digital”; // Linux 4.1.6-v7+ #810
int x, mute_state;
long i, currentVolume;
printf(“IQaudIO.com Pi-DAC Volume Control support Rotary Encoder) v1.5 Aug 30th 2015\n\n”);
wiringPiSetup ();
/* pull up is needed as encoder common is grounded */
pinMode (ENCODER_A, INPUT);
pullUpDnControl (ENCODER_A, PUD_UP);
pinMode (ENCODER_B, INPUT);
pullUpDnControl (ENCODER_B, PUD_UP);
encoderPos = pos;
// Setup ALSA access
snd_mixer_open(&handle, 0);
snd_mixer_attach(handle, card);
snd_mixer_selem_register(handle, NULL, NULL);
snd_mixer_load(handle);
snd_mixer_selem_id_alloca(&sid);
snd_mixer_selem_id_set_index(sid, 0);
snd_mixer_selem_id_set_name(sid, selem_name);
snd_mixer_elem_t* elem = snd_mixer_find_selem(handle, sid);
snd_mixer_selem_get_playback_volume_range(elem, &min, &max);
if (DEBUG_PRINT) printf(“Returned card VOLUME range - min: %ld, max: %ld\n”, min, max);
// Minimum given is mute, we need the first real value
min++;
// Get current volume
if (x = snd_mixer_selem_get_playback_volume (elem, SND_MIXER_SCHN_FRONT_LEFT, ¤tVolume))
printf("%d %s\n", x, snd_strerror(x));
else if (DEBUG_PRINT) printf(“Current ALSA volume LEFT: %ld\n”, currentVolume);
if (x = snd_mixer_selem_get_playback_volume (elem, SND_MIXER_SCHN_FRONT_RIGHT, ¤tVolume))
else if (DEBUG_PRINT) printf(“Current ALSA volume RIGHT: %ld\n”, currentVolume);
//Get current volumio volume level
long volumio_vol = 0;
FILE *fp = popen("/volumio/app/plugins/system_controller/volumio_command_line_client/volumio.sh volume",“r”);
fscanf(fp, “%ld”, &volumio_vol);
pclose(fp);
if( DEBUG_PRINT ) printf(“Volumio volume: %ld\n\n”, volumio_vol);
long sync_vol = 0; //This value will be calculated based on max volume value of ALSA
//Calculate volume level to synchronize
sync_vol = volumio_vol * ( max / 100);
snd_mixer_selem_set_playback_volume_all (elem, sync_vol);
/* monitor encoder level changes */
wiringPiISR (ENCODER_A, INT_EDGE_BOTH, &encoderPulse);
wiringPiISR (ENCODER_B, INT_EDGE_BOTH, &encoderPulse);
// Now sit and spin waiting for GPIO pins to go active…
while (1)
if (encoderPos != pos)
// get current volume
else if (DEBUG_PRINT) printf(" Current ALSA volume: %ld\n", currentVolume);
// Adjust for MUTE
if (currentVolume < min)
currentVolume = 0;
if (DEBUG_PRINT) printf(" Current ALSA volume set to min: %ld\n", currentVolume);
// What way did the encoder go?
if (encoderPos > pos)
pos = encoderPos;
currentVolume = currentVolume + 10;
// Adjust for MAX volume
if (currentVolume > max) currentVolume = max;
if (DEBUG_PRINT) printf("Volume UP %d - %ld", pos, currentVolume);
else if (encoderPos < pos)
pos = encoderPos;
currentVolume = currentVolume - 10;
// Adjust for MUTE
if (currentVolume < min) currentVolume = 0;
if (DEBUG_PRINT) printf("Volume DOWN %d - %ld", pos, currentVolume);
if (x = snd_mixer_selem_set_playback_volume_all(elem, currentVolume))
printf(" ERROR %d %s\n", x, snd_strerror(x));
} else if (DEBUG_PRINT){
printf(" Volume successfully set to %ld using ALSA!\n", currentVolume);
sync_vol = currentVolume * (100 / (float)max);
if(DEBUG_PRINT) printf("Sync volume: %ld\n", sync_vol);
//Fork a new process to update volumio volume level
pid_t pID = vfork();
if(pID == 0){
if(DEBUG_PRINT) printf("Setting volumio volume to %ld\n\n", sync_vol);
char command[1000];
char res[1000];
//Build command to update volumio volume level
sprintf(command, "/volumio/app/plugins/system_controller/volumio_command_line_client/volumio.sh volume %ld", sync_vol);
//Execute command
FILE *fp = popen(command, "r");
fscanf(fp, "%s", &res);
pclose(fp);
_exit(0);
// Check x times per second, MAY NEED TO ADJUST THS FREQUENCY FOR SOME ENCODERS /
delay(gpiodelay_value); / check pos x times per second */
// We never get here but should close the sockets etc. on exit.
snd_mixer_close(handle);
// Called whenever there is GPIO activity on the defined pins.
void encoderPulse()
+---------+ +---------+ 0
A | | | |
±--------+ ±--------+ ±---- 1
B | | | |
----+ ±--------+ ±--------+ 1
if (inCriticalSection==TRUE) return;
inCriticalSection = TRUE;
int MSB = digitalRead(ENCODER_A);
int LSB = digitalRead(ENCODER_B);
int encoded = (MSB << 1) | LSB;
int sum = (lastEncoded << 2) | encoded;
if(sum == 0b1101 || sum == 0b0100 || sum == 0b0010 || sum == 0b1011) encoderPos++;
else if(sum == 0b1110 || sum == 0b0111 || sum == 0b0001 || sum == 0b1000) encoderPos–;
lastEncoded = encoded;
[/code]
