I’d like to download Volumio, but only over HTTPS. The link at updates.volumio.org/pi/volumio/2 … pi.img.zip which resolves to
$ dig updates.volumio.org +short
149.210.234.235
An nmap scan of that IP address shows that ports 22, 80, 6969, and 7070 are open. If you didn’t want to have Comodo re-issue a certificate, you could use Let’s Encrypt for updates.volumio.org.
Additionally, would it be possible to switch from an MD5 sum to a SHA256 sum? Example from the current downloads page
IMAGE MD5: 097b17e54391fa6e172588fc74df394f
Thanks!
