If I try to use the Spotify Plugin I can login, but the O-Auth is not working.
It seems as if the server is down…
http://oauth-performer.dfs.volumio.org/
seems to be up again
All issues solved. Everything is back to normal working order.
Basically, an expired certificate messed up the ingress configuration on the Kubernetes cluster. All solved now;
