Hi
i have raspberry pi4 b 8gb
and i have 2 hdmi , can i run 2 display at same time ???, i have on HDM O port a 7"display with resolution 1024x600 i want to rub on HDMI a TV with the same resolution or Higher , is this posible ??
i already have input config.txt
initramfs volumio.initrd
gpu_mem=32
max_usb_current=1
dtparam=audio=on
audio_pwm_mode=2
dtparam=i2c_arm=on
disable_splash=1
hdmi_force_hotplug=1
force_eeprom_read=0
disable_overscan=1
config_hdmi_boost=7
hdmi_group=2
hdmi_mode=87
hdmi_drive=1
hdmi_cvt=1024 600 60 6 0 0 0
include userconfig.txt
and in userconfig text
max_framebuffers=2
can you help me thx A LOT
