Hi to all of you,
after testing the GPIO BUTTONS plugin, I am about to try to trigger PLAY with a motion sensor (ordered today…).
But since PLAY is also PAUSE, I’m wondering if it’s easy to set it so that sensor ON=PLAY, sensor OFF=PAUSE.
Did any of you tried this type of setup ? What would be your advice to achieve this ???
Thanks !!!
