I think the problem of the WebUI hang is related with this issue.
As soon as I use spaces in the NAS remotedir or user I cannot update the NAS settings any more.
At this point I cannot access to other settings menu, too.
I have found this message in /var/log/php_errors.log
Note that the _ does not work to replace the spaces.
I can successfully mount this directory replacing spaces with “\040” in the /etc/fstab file or "\ " with mount.
Final question: is there any way to reset configuration from terminal?
If not I need to flash the sdcard every time this problem occurs.
Hi Michelangelo,
finally I sorted it out. I did change a bit the php files.
Basically I did:
removed the substitution of \ with / (file /var/www/sources.php)
// $_POST[‘mount’][‘remotedir’] = str_replace(’\’, ‘/’, $_POST[‘mount’][‘remotedir’]);
In this way I can use the following syntax in the Web forms:
removed the quotes " from the mount command (file /var/www/inc/player_lib.php)
$mountstr = “mount -t cifs //”.$mp[0][‘address’]."/".$mp[0][‘remotedir’]." -o username=".$mp[0][‘username’].",password=".$mp[0][‘password’].",rsize=".$mp[0][‘rsize’].",wsize=".$mp[0][‘wsize’].",iocharset=".$mp[0][‘charset’].",".$mp[0][‘options’]." /mnt/NAS/".$mp[0][‘name’]."";
To remove the error
mount: Not a directory
This works for all my remote directories. I do not use path in the dos style with .
Now my NAS disk mounts. I changed the names of the directories next to my music collection to not contain ‘space’.
I mount /Public/Musik. The names I changed were /Public/SharedPictures (from /Public/Shared Pictures) and /Public/SharedVideos (from /Public/Shared Videos).
