Dear Volumionouts,
VirtualBox VM Resolution Configuration for Volumio
Important
This guide uses 1280x720 as an example resolution throughout. Replace with your desired resolution where applicable.
Disclaimer
Changes made with this guide are unsupported and may require a full factory reset or reinstall if something goes wrong. Use at your own discretion.
Overview
This guide covers forcing screen resolution for a Volumio 4 x64 VM running in VirtualBox without Guest Additions.
Three components need configuration:
- VirtualBox host settings (external to VM)
- GRUB bootloader (early boot)
- Xorg (X11 session)
Part 1: VirtualBox Host Configuration
Step 1: Find VM Name
Shut down the VM first.
Linux/Mac:
VBoxManage list vms
Windows (Command Prompt):
"C:\Program Files\Oracle\VirtualBox\VBoxManage.exe" list vms
Windows (PowerShell):
& "C:\Program Files\Oracle\VirtualBox\VBoxManage.exe" list vms
Output example:
"Volumio Bookworm" {809c7cdb-2092-49b7-987a-6ca77ebf5ea8}
"Ubuntu Server" {12345678-1234-1234-1234-123456789abc}
Step 2: Set Variables
Set both VM name and desired resolution.
Linux/Mac (bash):
export VM_NAME="Volumio Bookworm"
export RES="1280x720"
set VM_NAME=Volumio Bookworm
set RES=1280x720
$VM_NAME = "Volumio Bookworm"
$RES = "1280x720"
Common resolutions: 1280x720, 1920x1080, 1600x900, 1366x768
Step 3: Configure VM
Linux/Mac:
VBoxManage setextradata "$VM_NAME" "CustomVideoMode1" "${RES}x32"
VBoxManage modifyvm "$VM_NAME" --vram 128
VBoxManage modifyvm "$VM_NAME" --graphicscontroller vmsvga
"C:\Program Files\Oracle\VirtualBox\VBoxManage.exe" setextradata "%VM_NAME%" "CustomVideoMode1" "%RES%x32"
"C:\Program Files\Oracle\VirtualBox\VBoxManage.exe" modifyvm "%VM_NAME%" --vram 128
"C:\Program Files\Oracle\VirtualBox\VBoxManage.exe" modifyvm "%VM_NAME%" --graphicscontroller vmsvga
& "C:\Program Files\Oracle\VirtualBox\VBoxManage.exe" setextradata $VM_NAME "CustomVideoMode1" "${RES}x32"
& "C:\Program Files\Oracle\VirtualBox\VBoxManage.exe" modifyvm $VM_NAME --vram 128
& "C:\Program Files\Oracle\VirtualBox\VBoxManage.exe" modifyvm $VM_NAME --graphicscontroller vmsvga
Step 4: Verify Settings
Linux/Mac:
VBoxManage getextradata "$VM_NAME" "CustomVideoMode1"
VBoxManage showvminfo "$VM_NAME" | grep -E "VRAM|Graphics"
"C:\Program Files\Oracle\VirtualBox\VBoxManage.exe" getextradata "%VM_NAME%" "CustomVideoMode1"
"C:\Program Files\Oracle\VirtualBox\VBoxManage.exe" showvminfo "%VM_NAME%" | findstr /I "VRAM Graphics"
& "C:\Program Files\Oracle\VirtualBox\VBoxManage.exe" getextradata $VM_NAME "CustomVideoMode1"
& "C:\Program Files\Oracle\VirtualBox\VBoxManage.exe" showvminfo $VM_NAME | Select-String "VRAM|Graphics"
Alternative: VirtualBox GUI
- Shut down VM
- Select VM in VirtualBox Manager
- Settings > Display
- Set Video Memory: 128 MB
- Graphics Controller: VMSVGA (or try VBoxVGA/VBoxSVGA if issues)
Alternative: Edit .vbox File Directly
File locations:
- Linux: ~/VirtualBox VMs/VM_NAME/VM_NAME.vbox
- Windows: C:\Users\USERNAME\VirtualBox VMs\VM_NAME\VM_NAME.vbox
- macOS: ~/VirtualBox VMs/VM_NAME/VM_NAME.vbox
Shut down VM, then edit the .vbox file.
Find or add ExtraData section (substitute your resolution):
<ExtraData>
<ExtraDataItem name="CustomVideoMode1" value="WIDTHxHEIGHTx32"/>
<ExtraDataItem name="GUI/AutoresizeGuest" value="false"/>
</ExtraData>
Example for 1280x720:
<ExtraDataItem name="CustomVideoMode1" value="1280x720x32"/>
Find Display section and set:
<Display controller="VMSVGA" VRAMSize="128"/>
Graphics controller options: VMSVGA, VBoxVGA, VBoxSVGA
Part 2: Guest Configuration Script
Save as set-resolution.sh inside the Volumio VM.
#!/bin/bash
set -e
# Usage: sudo ./set-resolution.sh 1280x720
if [ -z "$1" ]; then
echo "Usage: $0 <resolution>"
echo "Example: $0 1280x720"
exit 1
fi
RES="$1"
CHANGED=0
# Validate format
if ! echo "$RES" | grep -qE '^[0-9]+x[0-9]+$'; then
echo "Error: Invalid resolution format. Use WIDTHxHEIGHT (e.g. 1280x720)"
exit 1
fi
echo "Setting resolution to: $RES"
echo ""
# --- xorg.conf ---
XORG_FILE="/etc/X11/xorg.conf.d/10-resolution.conf"
if [ -f "$XORG_FILE" ] && grep -q "Modes \"$RES\"" "$XORG_FILE"; then
echo "xorg.conf: already configured"
else
mkdir -p /etc/X11/xorg.conf.d
cat > "$XORG_FILE" << EOF
Section "Monitor"
Identifier "Monitor0"
HorizSync 30-80
VertRefresh 50-75
EndSection
Section "Screen"
Identifier "Screen0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
Modes "$RES"
EndSubSection
EndSection
EOF
echo "xorg.conf: created"
CHANGED=1
fi
# --- grub gfxmode ---
GRUB_FILE="/boot/efi/BOOT/grub.cfg"
if grep -q "set gfxmode=$RES" "$GRUB_FILE"; then
echo "grub gfxmode: already configured"
else
sed -i "s/set gfxmode=[0-9]*x[0-9]*/set gfxmode=$RES\n set gfxpayload=keep/" "$GRUB_FILE"
echo "grub gfxmode: updated"
CHANGED=1
fi
# --- kernel video parameter ---
if grep -q "video=$RES" "$GRUB_FILE"; then
echo "kernel video param: already configured"
else
if grep -q 'video=[0-9]*x[0-9]*' "$GRUB_FILE"; then
sed -i "s/video=[0-9]*x[0-9]*@[0-9]*/video=$RES@60/" "$GRUB_FILE"
echo "kernel video param: updated"
else
sed -i "s/\(linux.*vmlinuz.*\)/\1 video=$RES@60/" "$GRUB_FILE"
echo "kernel video param: added"
fi
CHANGED=1
fi
echo ""
if [ $CHANGED -eq 1 ]; then
echo "Changes made. Reboot to apply."
else
echo "No changes needed."
fi
Usage:
chmod +x set-resolution.sh
sudo reboot
Part 3: Manual xrandr (Temporary)
For immediate change without reboot (resets on reboot):
DISPLAY=:0 xrandr --output default --mode WIDTHxHEIGHT
DISPLAY=:0 xrandr --output default --mode 1280x720
To verify current resolution:
DISPLAY=:0 xrandr
The active mode shows an asterisk (*).
Troubleshooting
xrandr shows “Can’t open display”
Use: DISPLAY=:0 xrandr
Mode not available
Check available modes with DISPLAY=:0 xrandr and choose one listed.
Resolution resets after Volumio update
Re-run the guest script - Volumio may regenerate grub.cfg during updates.
Try different graphics controller
If resolution doesn’t stick, try changing controller in VirtualBox:
- VMSVGA (default, needs Guest Additions for best results)
- VBoxVGA (legacy, often works better without Guest Additions)
- VBoxSVGA (hybrid)
Notes
- Guest Additions cannot be installed on Volumio due to custom kernel without headers
- VRAM of 128 MB is sufficient for resolutions up to 4K
- grub.cfg is generated by Volumio build scripts - direct edits may be overwritten on system updates
