How to return from Camilla dsp
I am on an x86 system. I am playing around with the DSP plugin.
I tried the camilla dsp andit transferred me to the Camilla DSP UI.
Now How do i go back to the volumio UI?
What commands do i use since i see no way to get back to volumio UI and must restart.
txs
Nobody else have this problem? There are several other ways that you can exit the volumio UI with no way back. Surely there must be some command to return to the volumio UI…
Do you use it in web browser? What is your device?
I boot up Volumio on an old Gateway laptop.
Then I use the fusionDSP plugin and chose the pure camilla dsp GUI. That works great and i get switched over to the camilla gui. I do my audio adjustments, but i don’t know how to get out of the Camilla Gui and back to the volumio gui.
Txs
I see… Have you tried Alt + Left Arrow ?
Alt + left arrow does nothing, Alt + right arrow takes me to a google page and alt +left arrow takes me back to the Camilla gui.
I know this a problem… I don’t know… need to check.
Ok. Thank-you.
I have the same problem … can’t get out off Camilla DSP …
never found a solution. let me know if you have more success.
