How to reinstall volomio on PC
My Volumio is stuck in the middle of initialization, it’s looking for some USB. I tried reinstalling Volumio from a USB, and it boots up to url fine from the USB, but the “Install to hard drive” command that used to be in the ‘settings’ section is gone and can’t be found anymore.
What to do?
I suppose you‘re using it on an x86 platform?
Could you tell us which version (please don‘t say „latest“, exact numer required) you installed, before going into detail?
Volumio-3.832-2025-07-26-x86_amd64.zip on an x86 platform
thanks
In case Volumio doesn’t find any suitable storage device to install to, then the option is hidden (skipped) in the system options.
