Hi
I am using a Raspberry 3B+ with v2.55. and v2.565.
Currently ‘Autostart’ Plug-in is working well in case of start position in the list.
However if I set into ‘Play for Last position’ it only play from the start.
Even I try with ‘Autoplay’ plug-in which has a same function which is to play last entry in the list, it plays from the top in the list.
How can I play the last entry in the list?
Thank you in advance.
