Hi
Am I doing something wrong or is simply that Volumio does not support it ?
I’m using mconnect to stream to Volumio upnp render but I’m not getting the hi res stream.
Mconnect supports MQA 24 bit 96khz trough software but in volumio I only see 24 bit 48khz. Is this a Volumio limitation or a problem in mconnect?
By passing from 96 to 48 is there a significant impact in audio quality?
Has anyone successfully got a way to stream hi res stream trough upnp?
